KeyPad 4x4 Row Column Progression for LCD 16x2
LiquidCrystal_I2C lcd(0x27, 16, 2);
#include <Keypad.h>
const int ROW_NUM = 4; //four rows
const int COLUMN_NUM = 4; //four columns
char keys[ROW_NUM][COLUMN_NUM] = {
{'1','2','3', 'A'},
{'4','5','6', 'B'},
{'7','8','9', 'C'},
{'*','0','#', 'D'}
int R = 0;
int C = 0;
int R1 = 1;
int C1 = 0;
byte pin_rows[ROW_NUM] = {A15, A14, A13, A12}; //connect to the row pinouts of the keypad
byte pin_column[COLUMN_NUM] = {A11, A10, A9, A8}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), pin_rows, pin_column, ROW_NUM, COLUMN_NUM );
void setup(){
 lcd.init(); // display initialization
 lcd.clear();
 lcd.backlight(); // activate the backlight
char key = keypad.getKey();
if(key) //press a key on the 4x4 matrix keypad
  lcd.print(key);
  C++;
if(C>15)
  lcd.setCursor(C1, R1);
  lcd.print(key);
  C1++;
if(C1>16)
  lcd.clear();
  C=0;
  R=0;
if(C==0)// && R==0)
  lcd.print(key);
  C++;
Here When I use to press keys on keypad =>
  1. It starts printing from location (0,0) to (15,0)
  2. Then gets switch to Row 1 from (0,1) to (15,1)
  3. Then Screen gets clear !!
At this point I want to start the above 3 steps of function to continue the printing
But here in my code :
After clear screen , the keys are getting printed on a single location (0,0) displaying one key at a time only and it is not proceeding to (1,0) , (2,0) . . . . and so on like that !!!!!
Please help me in getting this . .
There's no R1++, nor R++, whatever it should be.....
Try this code:
#include <Keypad.h>
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
int R = 0;
int C = 0;
int R1 = 1;
int C1 = 0;
  lcd.clear();
  if (key) //press a key on the 4x4 matrix keypad
    lcd.print(key);
    C++;
    if (C > 16)
      lcd.print(key);
      C1++;
    if (C1 > 16)
      lcd.clear();
      C = 0;
      R = 0;
      C1 = 0;
      lcd.setCursor(C, R);
      lcd.print(key);
      C++;
OK Done !! Then how to move without these two ???
Sorry ,
not is if (C > 15) and if (C1 > 15).
Correct is if (C > 16) and if (C1 > 16).
Wowwww !!!!!!!!!
That is working :astonished: :open_mouth:
Great !!!
One thing I want to add as a feature here !!
As all the time i need to press keys repeatedly say key 1 so many times to print 1111111
Is there any option that I use to press and hold a single key and the printing will start automatically 11111111111111 like that until I release the key ????????
Ok Le me check !!
Oh Yes yes It was switching after 15 immediately
and now its all the way OK !!!
Please check #6 I am having a query there !!!
any solution regarding #6 sir ??
I don't know if it's possible.
You need to study the Keypad.h library to see if there is such a function to repeat characters.
Any good link to study that way ??
I found it on google:
"Using keypad.h HOLD to fire off continuous data?
Ya OK Le Me Go Thru it . . . Thanks !!
