Keypad error: was not declared in this scope
Hi everyone
I'm recently new to arduino
I tried a project with a keyboard an 3 leds
It works with two leds but when I write the code for the third led it says: "error: scanRow was not declared in this scope"
Appreciate the help
thx,
Kobydee
[code]
int rowCounter =0; // row counter
int columnCounter =0; // column counter
int foundColumn = 0;
boolean foundCol = false;
int keyValue = 0;
int noKey = 0;
boolean readKey = false;
int debounce = 300; // set this to the lowest value that gives the best result
const int row1 = 2;
const int row2 = 3;
const int row3 = 4;
const int row4 = 5;
const int colA = 8;
const int colB = 9;
const int colC = 10;
const int colD = 11;
const int redPin = 6; // onboard LED
const int greenPin = 12;
const int yellowPin = 13;
void setup(){
pinMode(row1, OUTPUT);
pinMode(row2, OUTPUT);
pinMode(row3, OUTPUT);
pinMode(row4, OUTPUT);
pinMode(colA, INPUT_PULLUP);
pinMode(colB, INPUT_PULLUP);
pinMode(colC, INPUT_PULLUP);
pinMode(colD, INPUT_PULLUP);
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(yellowPin, OUTPUT);
digitalWrite(redPin, LOW); // turn LED off
digitalWrite(greenPin, LOW);
digitalWrite(yellowPin, LOW);
void loop(){
if(noKey == 16){ // no keys were pressed
readKey = true; // keyboard is ready to accept a new keypress
noKey = 0;
for(rowCounter=row1; rowCounter<(row4 +1); rowCounter++){
scanRow(); // switch on one row at a time
for(columnCounter = colA; columnCounter <colD +1; columnCounter++){
readColumn(); // read the switch pressed
if (foundCol== true){
keyValue =(rowCounter-row1) +4*(columnCounter - colA);
if(readKey==true && noKey == 15){ // a key has been pressed
Serial.println(keyValue); // used for debug
if (keyValue == 13){
digitalWrite(redPin, !digitalRead(redPin)); // toggles LED ON/OFF
else{
if (keyValue == 14){
digitalWrite(greenPin, !digitalRead(greenPin)); // toggles LED ON/OFF
else{
// call to part of the sketch that will use the key number
readKey = false; // rest the flag
delay(debounce); // debounce
void scanRow(){
for(int j =row1; j < (row4 +1); j++){
digitalWrite(j, HIGH);
digitalWrite(rowCounter , LOW); // switch on one row
void readColumn(){
foundColumn = digitalRead(columnCounter);
if(foundColumn == 0){
foundCol = true;
else{
foundCol=false;
noKey=noKey +1; // counter for number of empty columns
keypad.ino (2.88 KB)
Please include your code in the post instead of attaching; it's small enough. People often use phones or tablets and can't read ino attachments.
Please edit your post
type [code]
paste your code after that
type [/code] after that
Format your code using Auto Format in the IDE and you will see your problem.
UKHeliBob:
hi
I did wat you asked me to do
But i still can't find the problem (my dad wrote this code and now he's at work(I'm new to arduino so...))
Here is your code Auto formatted
4x4 keyboard matrix
By Chris Rouse Oct. 2015
Connect:
Row 1 to Arduino pin 2
Row 2 to Arduino pin 3
Row 3 to Arduino pin 4
Row 4 to Arduino pin 5
Column A to Arduino pin 8
Column B to Arduino pin 9
Column C to Arduino pin 10
Column D to Arduino pin 11
Key identification:
(with connector at the top)
0 1 2 3
4 5 6 7
8 9 10 11
12 13 14 15
Connector:
Rows     Columns
X X X X  X X X X
1 2 3 4  A B C D
(Rows link keys from left to right,
columns link keys from top to bottom)
int rowCounter = 0; // row counter
int columnCounter = 0; // column counter
int keyValue = 0;
int noKey = 0;
const int row1 = 2;
const int row2 = 3;
const int row3 = 4;
const int row4 = 5;
const int colA = 8;
const int colB = 9;
  if (noKey == 16) // no keys were pressed
  noKey = 0;
  for (rowCounter = row1; rowCounter < (row4 + 1); rowCounter++)
    for (columnCounter = colA; columnCounter < colD + 1; columnCounter++)
      if (foundCol == true)
        keyValue = (rowCounter - row1) + 4 * (columnCounter - colA);
        if (readKey == true && noKey == 15) // a key has been pressed
          if (keyValue == 13)
              if (keyValue == 14)
                  if (keyValue == 14)
                void scanRow()
                  for (int j = row1; j < (row4 + 1); j++)
                void readColumn()
                  if (foundColumn == 0)
                    foundCol = true;
                    foundCol = false;
                    noKey = noKey + 1; // counter for number of empty columns
When Auto formatted function definitions should start on the left margin, like loop() and setup()
Does the scanRow() function definitiaon start on the left margin ? If then why not ? Is the code block that precedes it terminated correctly with one (or possibly more) right curly brackets ?
              if (keyValue == 14)
                  if (keyValue == 14)
The else block won't be executed if keyValue is 14, so it is pointless to test that keyValue is 14 in the else block. It will not be 14.
There is a Keypad library that properly handles reading 3x3, 3x4, and 4x4 keypads. Why not use that, instead of writing your own code, when you don't understand coding?
/Users/john/Documents/Arduino/sketch_jun27a/sketch_jun27a.ino: In function 'void loop()':
sketch_jun27a:46: error: 'scanRow' was not declared in this scope
sketch_jun27a:76: error: a function-definition is not allowed here before '{' token
                 void scanRow() {
The function is not declared because the function above it did not have amatching '}' for each '{'.
sketch_jun27a:57: error: expected '}' before 'else'
             else {
sketch_jun27a:61: error: expected '}' before 'else'
                 else {
These errors point out some of the places where a '}' was expected but not placed.
sketch_jun27a:99: error: expected '}' at end of input
And it looks like a bunch of other cases where '{' did not have a matching '}'. Check for matching brackets!
There may be some spare ones at the end of the program !
