Keypad for servo motors
I have coded a board to receive input from a keypad to power a pin, which will eventually connect to a ssc-32u. Though I can get the code to work, the if statements and other things necessary for it to work are not working
#include <Key.h>
#include <Keypad.h>
const byte Rows= 4; //number of rows on the keypad i.e. 4
const byte Cols= 3; //number of columns on the keypad i,e, 3
//we will definne the key map as on the key pad:
char keymap[Rows][Cols]=
{'1', '2', '3'},
{'4', '5', '6'},
{'7', '8', '9'},
{'*', '0', '#'}
//  a char array is defined as it can be seen on the above
//keypad connections to the arduino terminals is given as:
byte rPins[Rows]= {13, 12, 11, 10}; //Rows 0 to 3
byte cPins[Cols]= {9, 8, 7}; //Columns 0 to 2
// command for library forkeypad
//initializes an instance of the Keypad class
Keypad kpd= Keypad(makeKeymap(keymap), rPins, cPins, Rows, Cols);
int maxnum = 5;
int count = 0;
int tens = 10;
int ones = 1;
int tenths = .1;
int hundredths = .01;
int number = 0;
int distance = 1;
int velocity = 1;
int Time = 0;
pinMode(6, OUTPUT); //Set 13 as the car start button
pinMode(5, INPUT);
pinMode(13-7, INPUT);
const int motors = 6;
const int start_button = 5;
Serial.begin(9600);  // initializing serail monitor
//If key is pressed, this key is stored in 'keypressed' variable
//If key is not equal to 'NO_KEY', then this key is printed out
{count = 0;
char keypressed = kpd.getKey();
if (keypressed != NO_KEY); (count <maxnum);
  Serial.println(keypressed);
  count = count + 1; }
if (keypressed = '#');
   { count = 6;}
if (keypressed = '*');
   { count = 6;}
    if (count = 1);
  tens = tens * keypressed; }
    if (count = 2);
  ones = ones * keypressed;}
    if (count = 3);
  tenths = tenths * keypressed;}
    if (count = 4);
  hundredths = hundredths * keypressed;
  number = tens + ones + tenths + hundredths;
  Time = number / velocity ;}
        if (digitalRead(5) == HIGH);
         { digitalWrite(6, HIGH);
          delay(1000*Time);
          digitalWrite(6, LOW); }}
  if (count > 3);
   { count = 0;}
I tried a test program for the keypad, but it did not work either.
#include <Key.h>
#include <Keypad.h>
{'1', '2', '3'},
{'4', '5', '6'},
{'7', '8', '9'},
{'*', '0', '#'}
byte rPins[Rows]= {12, 11, 10, 9}; //Rows 0 to 3
byte cPins[Cols]= {8, 7, 6}; //Columns 0 to 2
int blinks = 0;
pinMode(13, OUTPUT);
 digitalWrite(13, LOW);
 if (keypressed > 0);
    digitalWrite(13, HIGH);
Also, How could I set up and code the servo board through the Arduino. The time the servos have to run is equal to the variable Time in the first expression, and the velocity is a constant to be adjusted later. I would Really Appreciate any answers.
