Keypad goes crazy (pro-micro and membrane keypad)
I have an Arduino Pro Micro (ebay clone), a 4x4 membrane keypad.
The code and everything like this works great, the problem I have is that if I touch the backside or the wires going from the keypad to the arduino, it goes crazy, it inputs all characters and numbers in a random order.
So what I'm thinking, may it be some pull-up resistor trouble ?
I have tested for shorts 50 times all over, and the code cant be the problem, since it works fine exept for when I touch the wires or backside of the membrane keypad.
Have anyone experienced something similar or have any tips what I can try ?
I have tried with two keypads, and two pro-micros, same problem with all.
So post the code?
taulen:
I don't know. Have you got any?
taulen:
Yes it can.
taulen:
So - the solution is obvious. Don't touch the backside or the wires going from the keypad to the Arduino. Solved!
{Did you realise there is in fact a proximity/ touch sensor library for the Arduino? How do you suppose it works?}
taulen:
I would most certainly be thinking along those lines. Of course, you are using the internal pull-ups, are you not? Silly to do otherwise, but you may not have the code quite right.
Of course, until you post the code - all of it - in code tags (using the [ # ] icon), we will never know, will we?
By popular demand, here comes the code :wink:
And thank you all for helping out !
/*############################## COUNTDOWN TIMER ##################################
Let's Make It Episode 42 (http://letmakeit.tv)
#include <Wire.h>
#include <LiquidCrystal.h>
#include <Keypad.h>
//constants for Control Pin
int relayPin = 21;
char currentTimeValue[4];
int currentState = 1;
int timerSeconds = 0;
int lpcnt = 0;
//define the keypad
const byte rows = 4;
const byte cols = 4;
char keys[rows][cols] = {
 {'1','2','3','A'},
 {'4','5','6','B'},
 {'7','8','9','C'},
 {'*','0','#','D'}
byte rowPins[rows] = {9,8,7,6};
byte colPins[cols] = {5,4,3,2};
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, rows, cols);
 * LCD RS pin to digital pin 12
 * LCD Enable pin to digital pin 11
 * LCD D4 pin to digital pin 5
 * LCD D5 pin to digital pin 4
 * LCD D6 pin to digital pin 3
 * LCD D7 pin to digital pin 2
LiquidCrystal lcd(10, 16, 14, 15, 18, 19);
lcd.begin(16, 2);
 //display main screen
 displayCodeEntryScreen();
 //setup and turn off relay
 pinMode(relayPin, OUTPUT);
 digitalWrite(relayPin, LOW);
 //setup default time to 00:00
 currentTimeValue[0]='0';
 currentTimeValue[1]='0';
 currentTimeValue[2]='0';
 currentTimeValue[3]='0';
 showEnteredTime();
 int l;
 char tempVal[3];
 char key = keypad.getKey();
 //key pressed and state is 1
 if (int(key) != 0 and currentState == 1) {
 switch (key) {
 case '*':
 relayStatus(false);
 showEnteredTime();
 currentState = 1;
 lpcnt = 0;
 timerSeconds = 0;
 case '#':
 tempVal[0] = currentTimeValue[0];
 tempVal[1] = currentTimeValue[1];
 tempVal[2] = 0;
 timerSeconds = atol(tempVal) * 60;
 tempVal[0] = currentTimeValue[2];
 tempVal[1] = currentTimeValue[3];
 tempVal[2] = 0;
 timerSeconds = timerSeconds + atol(tempVal);
 currentState = 2;
 default:
 currentTimeValue[0] = currentTimeValue[1];
 currentTimeValue[1] = currentTimeValue[2];
 currentTimeValue[2] = currentTimeValue[3];
 currentTimeValue[3] = key;
 showEnteredTime();
 if (currentState == 2) {
 if (int(key) != 0) {
 if (key == '*') {
 relayStatus(false);
 showEnteredTime();
 currentState = 1;
 lpcnt = 0;
 timerSeconds = 0;
 if (lpcnt > 9) {
 lpcnt = 0;
 --timerSeconds;
 showCountdown();
 if (timerSeconds <= 0) {
 currentState = 1;
 relayStatus(false);
 showEnteredTime();
 relayStatus(true);
 ++lpcnt;
 delay(100);
void showEnteredTime()
 lcd.setCursor(9,1);
 lcd.print(currentTimeValue[0]);
 lcd.print(currentTimeValue[1]);
 lcd.print("m:");
 lcd.print(currentTimeValue[2]);
 lcd.print(currentTimeValue[3]);
 lcd.print("s");
void relayStatus(bool state)
 if (state)
 digitalWrite(relayPin, HIGH);
void showCountdown()
 char timest[6];\
 clearScreen();
 lcd.setCursor(0,0);
 lcd.print("** Ferdig om: **");
 lcd.setCursor(0,1);
 lcd.print("***** ");
 sprintf(timest, "%d:%.2d", (timerSeconds/60), (timerSeconds - ((timerSeconds/60)*60)));
 lcd.print(timest);
 lcd.print(" *****");
void displayCodeEntryScreen()
 clearScreen();
 lcd.setCursor(0,0);
 lcd.print("*UV-EKSPONERING*");
 lcd.setCursor(0,1);
 lcd.print("Tid:     ");
void clearScreen()
 lcd.setCursor(0,0);
 lcd.print("                ");
 lcd.setCursor(0,1);
 lcd.print("                ");
And yes, I'm "using" the internal resistors. Haven't added any externally, and I thought that the library takes care of using the internal ones automatically ?
As you can see I'm using a slightly modified example found on the net.
