Extremely Sorry for the incorrect way of posting, will surely take care in future.
The blank lines & spaces were just for my understanding, but surely will make it a point to learn lessons from mistakes.. Thanks for your kind support, the code is as below -
#include <EEPROM.h>
#include <Keypad.h>
#include <LiquidCrystal.h>
LiquidCrystal lcd(13, 12, 11, 10, 9, 8);
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {A5, A4, A3, A2}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {A1, A0, 2, 3}; //connect to the column pinouts of the kpd
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
const int led_A_Pin = 7; // the pin numbers for the LEDs
const int led_B_Pin = 6;
const int ledread_A_Pin = 5; // connect externally pin 5 to pin 7 so the pin 5 will read value of pin 7
const int led_C_Pin = 4; //
float led_A_B_Interval; // = 3000; // The Blinking interval - Want to give this input via a keypad.
//( Both LED A & LED B to bling at same interval, turn ON simultaneously but turn OFF as per the Blink duration on time.)
float blinkDuration_B; // = 1500; // ON time of the LED B - Want to give this input via a keypad.
//( Number in millisecs that Led - B is ON )
const int blinkDuration_A = 500; // Preset time duration for ON time of LED A. no need of keypad input
// number of millisecs that Led's are on.
const int blinkDuration_C = 1000; //
int timeA; // Time A
int timeB; // Time B
int timeAdd = 0; // for adding in keypad
int value = 0; // the number accumulator
int key; // the key press
int isnum;
float blinkrate;
float blinktime;
byte led_A_State = LOW; // used to record whether the LEDs are on or off // LOW = off
byte led_B_State = LOW;
byte led_C_State = LOW;
int val = 0;
unsigned long currentMillis = 0; // stores the value of millis() in each iteration of loop()
unsigned long previousLed_A_Millis = 0; // will store last time the LED was updated
unsigned long previousLed_B_Millis = 0;
unsigned long previousLed_C_Millis = 0;
lcd.begin(16, 2);// set up the LCD's number of columns and rows:
lcd.clear();
pinMode(led_A_Pin, OUTPUT); // set the Led pins as output:
pinMode(led_B_Pin, OUTPUT);
pinMode(led_C_Pin, OUTPUT);
pinMode(ledread_A_Pin, INPUT);
currentMillis = millis();
Getnumber();
updateLed_A_State();
updateLed_B_State();
updateLed_C_State();
switchLeds();
void Getnumber(){
char key = keypad.getKey();
do
key = keypad.getKey(); // input the key
isnum = (key >= '0' && key <= '9'); // is it a digit?
if (isnum)
timeAdd = timeAdd * 10 + key - '0'; // accumulate the input number
} while (isnum || !key); // until not a digit or while no key pressed
if (key != NO_KEY) {
if (key == 'A') {
timeA = timeAdd;
if (timeA >= 50) { // want to input the value of led_A_B_Interval between 5 to 50 blinks per minute only
timeAdd = (50);
timeA = timeAdd;
if (timeA <= 5) { // want to input the value of led_A_B_Interval between 5 to 50 blinks per minute only
timeAdd = (5);
timeA = timeAdd;
EEPROM.put(1,timeA); // want to store the time in EEPROM for use even after turn on/off untill next change.
Serial.println(timeA);
lcd.setCursor(0,0);
lcd.print("Rate:");
lcd.setCursor(10,0);
lcd.print(timeA);
//lcd.print(" PM");
if (key == 'B') {
timeB = timeAdd;
if (timeB >= 30) { // want to input the value of Blink Duration ON time of LED - B between 0.5 to 3 seconds only.
timeAdd = (30);
timeB = timeAdd;
if (timeB <= 4) { // want to input the value of Blink Duration ON time of LED - B between 0.5 to 3 seconds only.
timeAdd = (4);
timeB = timeAdd;
EEPROM.put(2,timeB); // want to store the time in EEPROM for use even after turn on/off untill next change.
Serial.println(timeB);
lcd.setCursor(0,1);
lcd.print("On Time:");
lcd.setCursor(9,1);
lcd.print(timeB);
//lcd.print(" Sec");
timeAdd = 0;
void updateLed_A_State() {
blinkrate = EEPROM.get(1,timeA); // want to use the stored value of blink rate of LED A & B in EEPROM for use even after turn on/off untill next change.
led_A_B_Interval = (60*1000)/blinkrate; // conversion of the manual Blink Rate Per Minute input data to milliseconds for use.
if (led_A_State == LOW) { // if the Led is off, we must wait for the interval to expire before turning it on
if (currentMillis - previousLed_A_Millis >= led_A_B_Interval) {
led_A_State = HIGH;
previousLed_A_Millis += led_A_B_Interval;
else { // i.e. if led_A_State is HIGH // if the Led is on, we must wait for the duration to expire before turning it off
if (currentMillis - previousLed_A_Millis >= blinkDuration_A) { // time is up, so change the state to LOW
led_A_State = LOW; // and save the time when we made the change
void updateLed_B_State() {
blinktime = EEPROM.get(2,timeB); // want to use the stored value of blink time of LED B in
blinkDuration_B = 100*blinktime; // conversion of the manual Blink Time in seconds input data
to milliseconds for use. **Better if can input direct using decimal Point**
if (led_B_State == LOW) {
if (currentMillis - previousLed_B_Millis >= led_A_B_Interval) {
led_B_State = HIGH;
previousLed_B_Millis += led_A_B_Interval;
else {
if (currentMillis - previousLed_B_Millis >= blinkDuration_B) {
led_B_State = LOW;
void updateLed_C_State() {
val = digitalRead(ledread_A_Pin); // Read the input at pin 10 which is the status of Pin 13.
if (val == HIGH) {
led_C_State = HIGH;
if (val == HIGH) {
if (currentMillis - previousLed_C_Millis >= blinkDuration_C) {
led_C_State = LOW;
previousLed_C_Millis += blinkDuration_C;
void switchLeds() {
// this is the code that actually switches the LEDs on and off
digitalWrite(led_A_Pin, led_A_State);
digitalWrite(led_B_Pin, led_B_State);
digitalWrite(led_C_Pin, led_C_State);
