Keypad input to get LED to blink
I want to type in a specific numeric combination on a 4x4 keypad: '338', and when that happens I want to have a green LED blink 3 times. I have been using Tinkercad and when I start the simulation and press the correct numbers on the keypad, nothing happens. When I press the numbers on the keypad I will see them quickly flash then disappear in the Serial Monitor but the LED doesn't blink.
int h;
int z;
int e;
int m;
int a;
#include <Keypad.h>
// keypad type definition
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keys[ROWS][COLS] =
 {{'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}};
byte rowPins[ROWS] = {9, 8, 7, 6};  //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 4, 3, 2};  //connect to the column pinouts of the keypad
int count=1;
bool codeEntered = false;
Keypad myKeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
const int ledPin_1 = 11; // pin for LED
  pinMode(ledPin_1, OUTPUT);
// function for blinking LED
void blinkLED() {
  for (int i = 0; i < 3; i++) {
    digitalWrite(ledPin_1, HIGH);
    delay(250);
    digitalWrite(ledPin_1, LOW);
    delay(250);
  char key = myKeypad.getKey();
  if (key != NO_KEY) {
    int a = key - '0';
    Serial.println(count);
    Serial.println("a=" + String(a));
    switch (count){
      case 1:
        if (key != NO_KEY){
        h = a * 100;
        Serial.println("h=" + String(h));
      case 2:
        if (key != NO_KEY){
        z = a * 10;
        Serial.println("z=" + String(z));
      case 3:
        if (key != NO_KEY){
        e = a;
        Serial.println("e=" + String(e));}
        m = h + z + e;
        Serial.println("m=" + String(m));
        if (m == 338) {
          codeEntered = true; // check if code entered is '338'
  count++;         //adds 1 to count
  if (count==4)     //checks for count=4
    count=1;
    if (codeEntered) {
     blinkLED();
    }            //reset count
I tried a different code to check that the keypad was hooked up correctly and when I do this one the serial monitor prints the number I press and it stays in the serial monitor, whereas when i do my original code it flashes for less than 1 second then disappears. So I am assuming there is something wrong with my code and not my circuit setup.
#include <Keypad.h>
 {{'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}};
    Serial.println(key);
Your "blinkLED()" function is giving you three "ON" flashes over a span of .75 second (3/4 second). Maybe increase the delay to 1000ms?
Collect the key read in loop and check for the combination.
