I’m using the multi-key example from the keypad library. Currently the code will print the status of the key press (pressed, released, hold) and store up to 10 active key presses at any given time.
I would like to print a number (1-10) each time a new key is pressed (eg 7 keys held down = print number 7)
I’m trying to do that with ‘findInList’ which i believe should return an index(1-10) from ‘kpd.key’ array of keys currently held down.
Any help is much appreciated
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {1, 2, 3, 4}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {5, 6, 7}; //connect to the column pinouts of the kpd
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
unsigned long loopCount;
unsigned long startTime;
String msg;
loopCount = 0;
startTime = millis();
msg = "";
loopCount++;
if ( (millis()-startTime)>5000 ) {
Serial.print("Average loops per second = ");
Serial.println(loopCount/5);
loopCount = 0;
// Fills kpd.key[ ] array with up-to 10 active keys.
// Returns true if there are ANY active keys.
if (kpd.getKeys())
for (int i=0; i<LIST_MAX; i++) // Scan the whole key list.
if ( kpd.key[i].stateChanged ) // Only find keys that have changed state.
switch (kpd.key[i].kstate) { // Report active key state : IDLE, PRESSED, HOLD, or RELEASED
case PRESSED:
msg = " PRESSED.";
case HOLD:
msg = " HOLD.";
case RELEASED:
msg = " RELEASED.";
case IDLE:
msg = " IDLE.";
Serial.print("Key ");
Serial.print(kpd.key[i].kchar);
Serial.println(msg);
int position_in_list;
position_in_list = findInList(10);
Serial.print(position_in_list);
} // End loop
