Keypad - Multiple Value Read [resolved]
Good Morning, I'm trying to using keypad and then read a multiple value ... in the specific cases I'd like to press '*' blink 2 times the led and then read the second one value for example one ... and then put everything inside a variable and print it on serial ... due the fact Im not able to say to the keypad for the second charachter after blink 2 times ... wait at max un second if the user I press key read the keypad read a key otherwise go on ... below the code ... is there someone that can help me ? thanks Andrea
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] = {
  {'1','2','3'},
  {'4','5','6'},
  {'7','8','9'},
  {'*','0','#'}
byte rowPins[ROWS] = {8, 7, 6, 5}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {4, 3, 2}; //connect to the column pinouts of the keypad
Keypad customKeypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup(){
  pinMode(13, OUTPUT);
  digitalWrite(13,LOW);
void loop(){
  char customKey = customKeypad.getKey();
  char customKey2;
  char testo[1];
  if (customKey != NO_KEY)
    if (customKey = '*')
       int a = 1;
       int cont = 3;
       asled(a,cont);
       customKey2 = customKeypad.getKey();
       a = 1;
       cont = 4;
       asled(a,cont);
       testo[0] = customKey;
       testo[1] = customKey2;
    Serial.println(testo);
void asled(int a,int cont)
  for (a = 1; a < cont; a++)
     digitalWrite(13, HIGH);
     delay(150);
     digitalWrite(13, LOW);
     delay(150);
to read multiple keys can imply that you need a keybuffer.
Add a timer (millis based) that checks the duration between keypresses and if too long wipe the buffer.
char testo[1]; is an array of length 1 so only index 0 is valid and you use index 1 too , will overwrite something in memory.
some code idea how to do the wiping and buffering
char buffer[10];
int index = 0;
unsigned long lastKey = 0;
  // read a key
  char key = customKeypad.getKey();
  if (key != NO_KEY)
    buffer[index++] = key;
    buffer[index] = '\0'; // keep string correctly terminated ;
    lastKey = millis();
  // test wipe time
  if ((millis() - 2000 > lastKey) || index == 9) // after 2 seconds or buffer full
    clearBuffer();
  if (buffer[0] == '*' && strlen(buffer)>1)
    switch(buffer[1])
    case '0' :
      asled(10);
    case '1' :
      asled(20);
    default :
      asled(5);
  if (buffer[0] == '#' && strlen(buffer)>1)
    switch(buffer[1])
    case '0' : Serial.println("Hello ");
    case '1' : Serial.println("Goodbye ");
    default :
      asled(5);
  Serial.println(buffer);
void clearBuffer()
    index = 0;
void asled(int cont)
  for (int a = 0; a < cont; a++)
     delay(150);
     delay(150);
Ciao, it's a very good idea :slight_smile: I will try and then I'll let you know :slight_smile: ,
Perfect, it's work
I've added also end command :slight_smile: thanks
warms regards,
Andrea
