Keypad not printing to PC applications.
Arduino Nano. What do I need to add to this to print the outputs to a PC? Right now the outputs only print to serial monitor.
#include <Keypad.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {9, 8, 7, 6}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {5, 4, 3, 2}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
void loop(){
char customKey = customKeypad.getKey();
if (customKey){
Serial.println(customKey);
You need a board with a 32U4 or some other processor that can emulate a USB keyboard. There is library support for that. But the Nano lacks the USB hardware, so it can't work.
What is the most simplistic model to get just for creating a custom keypad you provide inputs to a PC?
The Arduino Leonardo?
Leonardo, or Pro Micro. However, I'm taking a wild guess at what you mean by "simplistic". You didn't explain anything about your project.
It's called an "HID", Human Interface Device.
I an a novice for Arduinos and programming in general.
I am building a custom keypad for gaming. A 4x4 or 4x5 grid that I can customize what keypress is being sent to the PC.
Yes, but... enclosure? Size? Or you can decide. If it was me, I would go for the Pro Micro. I have a few kicking around that I use when I need two serial ports (I haven't played with HID yet). It's smaller and easier to connect to than the Leonardo, for a permanent project. I think a "Blue Pill" will do it also, but it's not as easy to program.
The good news is - you actually picked a pretty easy project.
Alright, I have the Arduino Leonardo now.
All I want to do is have the 4x4 grid below print to applications on a PC. Is this possible with Keyboard.print() or something similar? Or can this not be done with the keypad 4x4 grid?
#include <Keypad.h>
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
void setup(){
void loop(){
  if (customKey){
it is a huge difference between sending a byte over a serial connection based on a virtual comport or sending a "USB-signal" that shall have the meaning of a HID (human interface device). To make it even more clear a serial-connection is a NOT-HID-connection.
For sending keypresses the same way as from a USB-keyboard the connection must be a HID-connection.
This requires a microcontroller-board with USB-HID-capabilities like Arduino-leonardo.
Inside your program you are totally free to program whatever you want to cause sending "keystrokes" it just depends on your code. So you could even make a program that measures the moisture of a hamburger and based on the moisture-value send different USB-Keyboard-keystrokes,
There is one part in your program read-in (whatever)
and another part based on some rules (if-conditions) what USB-keyboard-keystrokes shall be send.
This is called: Input processing output principle.
Sending USB-keyboard-Keystrokes is done by other commands than Serial.print.
It has to be done with function-calls of functions of a USB-HID-library (which I don't know the names because I haven't used one ever yet.
EDIT: I have looked up the examples: there is a entry called USB this entry has subentries keyboard-messages etc.
best regards Stefan
dougn0782:
Look at the examples of the Keyboard library. Yes, it can be done.
I found this code in another forum and it functions just as I am hoping. I just need to modify the row and columns. Thanks for the inputs.
#include <Keypad.h>
#include <Keyboard.h>
const byte ROWS = 2; //two rows
const byte COLS = 2; //two columns
char keys[ROWS][COLS] = {
{'1','2'},
{'3','4'}
byte rowPins[ROWS] = {3, 4}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {6, 7}; //connect to the column pinouts of the keypad
Keypad customKeypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
void setup(){
void loop(){
if (customKey){
//Keyboard.write("key");
Serial.println(customKey); }
if (customKey == '1'){
Keyboard.write ('A');
if (customKey == '2'){
Keyboard.write ('B');
if (customKey == '3'){
Keyboard.write ('C');
if (customKey == '4'){
Keyboard.write ('D');
