Keypad not working properly with Arduino. show wrong value on serial monitor
type or paste code here
 #include <Keypad.h>
 #include "LedControl.h"
LedControl lc = LedControl(11,3,4,1); //DIN, SCK, LOAD,1xMAX7219
int a=20;
int b=30;
int c=37;
int d=40;
const byte ROWS = 4;
const byte COLS = 4;
char hexaKeys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = { A0, A1, A2, A3};
byte colPins[COLS] = { A4, 5, 6, 7};
Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
//  inputString.reserve(10);
  lc.shutdown(0,false);  // Wake up the display
  lc.setIntensity(0,7);
   //lc2.setIntensity(0,7);// Set Brightness 0-15
  lc.clearDisplay(0);  // Clear display
    char customKey = customKeypad.getKey();
    customKey=customKey-'0';
    if(customKey=='A'){// when press it go to function shahbaz.
      shahbaz();
void shahbaz(){
    long  int t=a*customKey;
      Serial.print(t);
      Serial.print(customKey);
       long   int t=customKey*a; // here get value from keypad and multiply with value of //int a but it show nothing when i print this value on serial monitor it show -960
  int digitOne =    (t%10);
    int digitTwo =    (t/10)%10;
      int digitThree =  (t/100)%10;
      int digitFour =   (t/1000)%10;
      int digitFive =   (t/10000)%10;
      int digitSix =    (t/100000)%10;
      int digitSeven=   (t/1000000)%10;
      int digitEight =  (t/10000000)%10;
    //MSB digitEight, LSB digitOne
      lc.setDigit(0,7,digitEight,false);
      lc.setDigit(0,6,digitSeven,false);
      lc.setDigit(0,5,digitSix,false);
      lc.setDigit(0,4,digitFive,false);
      lc.setDigit(0,3,digitFour,false);
      lc.setDigit(0,2,digitThree,false);
      lc.setDigit(0,1,digitTwo,false);
      lc.setDigit(0,0,digitOne,false);
Good work posting the code in code tags... but was there a question you are looking for help on?
You posted the wrong code. There is no "else if". Nothing is printed to serial monitor.
yes i want some help
Then clearly tell us what is not working as you expect.
when i press A from keypad it call the function shahbaz() , then i enter some value from keypad which multiply with int a and show results on seven segment .but show no results on seven segment display.when i print this result on serial.monitor
it show wrong answer like(-960, 000).
Your code doesn't compile
then how i compile it?
remove the code the compiler doesn't like...
i don't understand
Correct. You should try to Google Arduino for beginners.
you are right for google arduino for beginners.
haha
