keypad reading three numbers for led rgb
i am using Adafruit_NeoPixel library for manage my led strip, i add to the circuit keypad for read the code for some color as you can see
void singleColor(){
  red = readNumber();
  green = readNumber();
  blu = readNumber();
  colorWipe(strip.Color(red, green, blu), 50);
the other function :
int readNumber(){
    Serial.println("porcodiooo2");
    int tmp;
    char key = customKeypad.getKey();
  while(key!='#'){
         switch (key){
         case NO_KEY:
            Serial.println("porcodiooo3");
         case '0': case '1': case '2': case '3': case '4':
         case '5': case '6': case '7': case '8': case '9':
            Serial.println("letto numero");
            inputString += key;               // append new character to input string
         case '*':
            Serial.println("sbagliato");
            inputString = "";
    inputInt = inputString.toInt(); // YOU GOT AN INTEGER NUMBER
    tmp = inputInt;
    Serial.println("dentro read controllo #");
    Serial.println(inputInt);
    return tmp;
    inputString = "";
i call this inside
void loop(){
  char customKey = customKeypad.getKey();
  int key = int(customKey);
  if(key){
    functionWrapper(key);
  void functionWrapper(int fun){
    switch (fun) {
    case A:
     rainbowCycle(20);
    case B:
      singleColor();
    case C:
      theaterChase(strip.Color(127, 127, 127), 50); // White
    case D:
      turnoff();
  delay(1);        // delay in between reads for stability
i need to stop the loop until it read 3 values, so i can use :
 colorWipe()
any advice?
Well of course the error here is in this suggestion of “stop the loop”.
You need to study this thread to understand how coding works. :sunglasses:
