Keypad to LCD
Hey guys I am trying to get a keypad to input onto an LCD. I want the value to always be 6 characters long and to have 3 decimal places showing. when I enter a key, I want the 3rd decimal place to take the character of the key and each of the previous characters to slide 1 position to the left. ie if the screen is showing “76.532” and I use the keypad to enter the number “1”. I want the display to drop the seven, shift all the numbers one spot to the left, and insert a “1” on the end. this would give me the number “65.321”.
ignore the millis(). that is just there so I can ref a reset.
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(8, 9, 10, 11, 12, 13);//RS,EN,D4,D5,D6,D7
#include <Keypad.h>//header for keypad commands enabling
const byte ROWS = 4; // Four rows
const byte COLS = 4; // Three columns
// Define the Keymap
char keys[ROWS][COLS] = {
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'#','0','*','D'}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 4,5,6,7 };
// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 0,1,2,3 };
//  Create the Keypad
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
char a=1;
float b=.02;
float c=.3;
float e=5;
float f=60;
float ReturnPostionVar = a+b+c+e+f;
  lcd.begin(16, 2);//initializing LCD
  lcd.print("Return Pos");
  lcd.setCursor(0,1);
  lcd.print(ReturnPostionVar);
  char key = kpd.getKey(); //storing pressed key value in a char
  if (key != NO_KEY)
 lcd.setCursor(0,1);
 lcd.print("");
float f=e*10;
float e=c*10;
float c=b*10;
float b=a*10;
float a=key*.001;
float ReturnPostionVar=a+b+c+e+f;
 lcd.leftToRight();
      lcd.print(ReturnPostionVar); //showing pressed character on LCD
  lcd.rightToLeft();
lcd.setCursor(15,1);
lcd.print(millis()/1000);
    float a = key * .001;
The program already has a problem because key is an ASCII character not a number. So when you press 1, key actually holds 49 in decimal. To convert the ASCII code for a number to its actual number subtract '0'
UKHeliBob are you saying it needs to be like below?
float a = ( key - 0 ) * .001;
It helps to have an ASCII table handy while thinking about this. Observe the decimal values for the various characters. Note that the numerals 0-9 are not represented with their actual values. That is, the numeric value 3 is not represented as b00000111. So, subtracting a numeric value of zero ( all bits off ) from an ASCII ‘1’ will leave you with the original value. Subtracting an *ASCII * ‘0’ however…
Thank you guys for helping through that. Does it hold the number as an actual number now? I am going to be comparing it to a sensor value.
So it is scrolling right to left as i want it to and it is keeping the numbers as expected but it will only hold 2 decimal places. I can not get it to show the third?
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'#','0','*','D'}
float a=.001;
float b=.01;
float c=.1;
float e=0;
float f=10;
  lcd.setCursor(0,1);
  if (key != NO_KEY)
 lcd.setCursor(0,1);
 lcd.print("");
 f = e*10;
 e = c*10;
 c = b*10;
 b = a*10;
 a = (key-48) *0.001;
 lcd.leftToRight();
  lcd.rightToLeft();
Don't you know? Print whatever variable you are waving your arms about, and see what it contains. Is that what you expect?
