"keypad" was not declared in this scope
#include <Password.h>
#include <LiquidCrystal.h>
#include <Keypad.h>
Password password = Password(“2346”);
int dlugsoc = 4;
LiquidCrystal lcd( A0, A1, A2, A3, A4, A5);
int buzzer = 10;
int ledGreen = 11;
int ledRed = 12;
int ilosc;
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
{‘1’,‘2’,‘3’,‘A’},
{‘4’,‘5’,‘6’,‘B’},
{‘7’,‘8’,‘9’,‘C’},
{’*’,‘0’,’#’,‘D’}
byte rowPins[ROWS] = {5, 4, 3, 2}; //connect to the row pinouts of the kpd
byte colPins[COLS] = {9, 8, 7, 6}; //connect to the column pinouts of the kpd
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
unsigned long loopCount;
unsigned long startTime;
String msg;
keypad.aadEventListener(keypadvent);
pinMode(ledRed, OUTPUT);
pinMode(ledGreen, OUTPUT);
pinMode(buzzer, OUTPUT);
digitalWrite(ledRed, HIGH);
digitalWrite(ledGreen, LOW);
lcd.begin(16, 2);
lcd.setCursor(0,0);
lcd.print(" BIENVENIDO ");
lcd.setCursor(0,1);
lcd.print(“INGERSE CODIGO”);
keypad.getKey();
void keypadEvent(KeypadEvent eKey)
switch (keypad.getKey())
case PRESSED:
int i;
for( i= 1; i<= 1; i++ )
digitalWrite(buzzer, HIGH);
delay(200);
digitalWrite(buzzer, LOW);
delay(100);
Serial.print("Pressed: ");
Serial.print(eKey);
switch (eKey)
  • case"#":
  • break;
  • case"*";
  • break;
default:
ilosc=ilosc+1;
password.append(eKey);
//Serial.print(ilosc);
if(ilosc == 1)
lcd.clear();
lcd.setCursor(1,0);
lcd.print(" < PIN >");
lcd.setCursor(0,1);
lcd.print("");
if(ilosc == 2);
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.print("**
if(ilosc == 3);
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.print("
if(ilosc == 4);
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.print("
if(ilosc == 5);
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.print(“");
if(ilosc == 6);
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.print("
if(ilosc == 7);
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.print("*******");
if(ilosc == 8);
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.print("********
if(ilosc == dlugosc)
delay(250);
checkPassword();
ilosc = 0;
void checkPassword()
if (password.evaluate())
int i;
for( i = ; i <= 3; i++ )
delay(120);
delay(70);
ilosc = 0;
password.reset();
Serial.print(“Correcto”);
digitalWrite(ledRed, LOW);
digitalWrite(ledGreen, HIGH);
lcd.clear();
lcd.setCursor(0,1);
lcd.print("<>");
delay(2000);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
int i;
for( i = ; i <= ; i++ )
delay(300);
delay(100);
ilosc = 0;
password.reset();
Serial.print(“Error”);
lcd.clear();
lcd.setCursor(0,0);
lcd.print("<>");
delay(2000);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
} // End loop
Hi and welcome.
Some stuff to help you on your way (click!)
#include <Keypad.h>
int dlugsoc = 4;
int buzzer = 10;
int ledGreen = 11;
int ledRed = 12;
int ilosc;
{‘1’,‘2’,‘3’,‘A’},
{‘4’,‘5’,‘6’,‘B’},
{‘7’,‘8’,‘9’,‘C’},
{’*’,‘0’,’#’,‘D’}
String msg;
lcd.begin(16, 2);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
keypad.getKey();
case PRESSED:
int i;
delay(200);
delay(100);
Serial.print(eKey);
switch (eKey)
  • case"#":
  • break;
  • case"*";
  • break;
default:
ilosc=ilosc+1;
if(ilosc == 1)
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.print("");
if(ilosc == 2);
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.print("**
if(ilosc == 3);
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.print("
if(ilosc == 4);
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.print("
if(ilosc == 5);
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.print(“");
if(ilosc == 6);
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.print("
if(ilosc == 7);
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
if(ilosc == 8);
lcd.clear();
lcd.setCursor(1,0);
lcd.setCursor(0,1);
lcd.print("********
delay(250);
checkPassword();
ilosc = 0;
int i;
delay(120);
delay(70);
ilosc = 0;
password.reset();
lcd.clear();
lcd.setCursor(0,1);
lcd.print("<>");
delay(2000);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
int i;
delay(300);
delay(100);
ilosc = 0;
password.reset();
lcd.clear();
lcd.setCursor(0,0);
lcd.print("<>");
delay(2000);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
} // End loop
You missed this part:
