Keypad with Multi-TASKS
Hi, i am new to ARDUINO and i bought Arduino Mega 2650, The short story of what I am trying to do is making TASKS with keypad as the following sequence :
if i Press >> "1" , "2" , "#" >> first Led ON, if i Press >> "1" , "3" , "#" >> second Led ON, if i Press >> "1" , "4" , "#" >> Third Led ON, and so on.
Can any one help me !!!
Do you plan to press all 3 keys at the same time, or one after the other. These options will need different approaches to the coding.
I will assume you intend to press the keys one after the other.
You need to have some way to know when a key press sequence starts and ends. Pressing the # key might signify the end (and hence the start of a new sequence) but what happens if someone only presses one or two keys and then goes away. A long gap might be another signal for an end/start of a sequence.
Once your code knows when a sequence is starting it needs to record the keys that are pressed until there is a # key or a timeout. The simplest way would probably be to save them into successive elements of an array. If a complete sequence is received you would then need a piece of code that decides what action to take.
...R
yes, i need one after the other
code:
#include <Keypad.h>
const int LED_1 = 30;
const int LED_2 = 31;
const int LED_2 = 32;
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char hexaKeys[ROWS][COLS] = {
  {'1','2','3','F1'}
  {'4','5','6','F2'},
  {'7','8','9','F3'},
  {'mode','0','cancel','Enter'}
byte rowPins[ROWS] = {50, 48, 46, 44};
byte colPins[COLS] = {51, 49, 47, 45};
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
  pinMode(LED_1, OUTPUT);
  pinMode(LED_2, OUTPUT);
  pinMode(LED_3, OUTPUT);
  char customKey = customKeypad.getKey();
That looks like a promising start.
It would be even better if you read the How to Use This Forum and put your code in code tags so it looks like this
...R
