Hey folks. I have google it but didn´t find a reasonable explanation. Here it is:
I have a sketch, with LCD 16x2 and 4x3 keypad and all works perfect in the protoboard.
So for my project I ordered a PCB (a professional one with my design done in easyeda).
I soldered all terminals and assembled the Arduino in the PCB. LCD works great but the Keypad is like crazy.... inputting all kind of number even when I don't touch it...
I checked ten times the route, solder, cable, etc... all good.
My sketch works great in the protoboard. In same pin of the arduino, etc.
any ideas?
is it any kind of signal interference caused by the pcb or something like that?
looks like the keypad is over sensitive or something like that.
That's a funny-looking schematic. I could almost think that you took a photo of the PCB.
If you suspect that the PCB is not working, then verify that the PCB matches the schematic. It doesn't matter how pretty it looks if you've shorted two pins together with a track that's incorrect.
That was a picture of the PCB.
Here is attached the Schematic.
Note that GND and +5V are both coming from another PCB through the 15 pin head male.
Again... the keypad is working... but ultra sensitive... If I merely touch it 5 number show up in the LCD.
When I connect the same Arduino, same code, same keypad in the Protoboard, this doens´t happen.
Let's see... no bypass capacitors, no mosfet gate resistors, IRF530's not logic rated.
Looks like some very basic but major design errors. Would need to see the board layouts as well, it's likely there are more omissions and mistakes there as well.
The current-limit resistors are adjacent to the MEGA symbol. Their values are all overlapping but it looks like they are 330 ohms. LED7-12 don't have resistors but they're obviously plugged into some module which might have the necessary resistors.
Without further information on the keypad, it's impossible to tell if it's properly connected. Pin 8 might have some necessary function (like ground) that isn't shown here.
The numbered pins going to the LCD connector at the top-right are going to be really confusing. 11 goes to 11 but 8 (from A8) goes to 14. I hope that makes sense to you 1 week from now because it doesn't make sense to me right now.
And just as some layout advice: ground symbols always point down. They should never be sideways.
MorganS:
Ahh yes... I just see them now..
Thanks @MorganS
Tom..... :o :o :o
