Attempting to connect a 3x4 Matrix Keypad through an I2C pin extender (PCF8574) on Feather M0, a compiler error is thrown when trying to compile the example files which use the keypad_I2C library.
The source code is the example from the folder Keypad_I2C\examples\EventKeypad_I2C\EventKeypad_I2C.ino
The TwoWire constructor called from Keypad_I2C constructor seems to be looking for a SERCOM and the SDA and SCL pin numbers?
Any suggestions on how to get this working?
Thanks!
The Compiler error:
In file included from C:\Users\me\AppData\Local\Temp\arduino_keypads-master\Keypad_I2C\examples\EventKeypad_I2C\EventKeypad_I2C.ino:12:0:
C:\Users\me\Documents\Arduino\libraries\Keypad_I2C/Keypad_I2C.h: In constructor 'Keypad_I2C::Keypad_I2C(char*, byte*, byte*, byte, byte, byte, byte)':
C:\Users\me\Documents\Arduino\libraries\Keypad_I2C/Keypad_I2C.h:44:48: error: no matching function for call to 'TwoWire::TwoWire()'
Keypad(userKeymap, row, col, numRows, numCols) { i2caddr = address; i2cwidth = width;}
C:\Users\me\Documents\Arduino\libraries\Keypad_I2C/Keypad_I2C.h:44:48: note: candidates are:
In file included from C:\Users\me\Documents\Arduino\sketch_0913_kpdtest_pcf8574\sketch_0913_kpdtest_pcf8574.ino:6:0:
C:\Users\me\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.2.3\libraries\Wire/Wire.h:35:5: note: TwoWire::TwoWire(SERCOM*, uint8_t, uint8_t)
TwoWire(SERCOM *s, uint8_t pinSDA, uint8_t pinSCL);
C:\Users\me\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.2.3\libraries\Wire/Wire.h:35:5: note: candidate expects 3 arguments, 0 provided
C:\Users\me\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.2.3\libraries\Wire/Wire.h:32:7: note: constexpr TwoWire::TwoWire(const TwoWire&)
class TwoWire : public Stream
C:\Users\me\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.2.3\libraries\Wire/Wire.h:32:7: note: candidate expects 1 argument, 0 provided
C:\Users\me\AppData\Local\Arduino15\packages\adafruit\hardware\samd\1.2.3\libraries\Wire/Wire.h:32:7: note: constexpr TwoWire::TwoWire(TwoWire&&)
exit status 1
Error compiling for board Adafruit Feather M0.
