KeypadEvent error
This is my first program to ever write and I'm using a guide book, however I get an error message every time I try to compile: 'variable or field 'keypadEvent' declared void.' I've double and triple checked my libraries. I am not a programmer, I'm just a teacher trying to help a student with a science project, please help...
#include <Password.h>
#include <Keypad.h>
#include <Servo.h>
Servo myservo;
Password password = Password("2468"); // Set Password
const byte ROWS = 4; // Set four rows
const byte COLS = 4; // Set four columns
char keys[ROWS][COLS] = { // Define the keymap
  {'1','2','3','A'},
  {'4','5','6','B'},
  {'7','8','9','C'},
  {'*','0','#','D'}
byte rowPins[ROWS] = { 9,8,7,6 };  //Pins connected to keypad
                                   // ROW0, ROW1, ROW2 and ROW3
byte colPins[COLS] = { 5,4,3,2, }; //Pins connected to keypad
                                   // COL0, COL1 and COL2
//create keypad
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
void setup () {
  delay(200);
  pinMode(11, OUTPUT);  // Set green LED as output
  pinMode(12, OUTPUT);  // Set red LED as output
  myservo.attach(13);  //Pin connected to servo
  keypad.addEventListener(keypadEvent);  //Add an event listener to detect keypresses
  keypad.getKey();
  myservo.write(0);
void keypadEvent(KeypadEvent eKey) {
  switch (keypad.getState()) {
    case PRESSED:
    Serial.print("Pressed: ");
    Serial.println(eKey);
    switch (eKey) {
      case '*': checkPassword(): break;
      case '#': password.reset(); break;
      default: password.append(eKey);
void checkPassword () {
  if (password.evaluate() ){
    Serial.println("Success");  // If the password is correct...
    myservo.write(90);          // Move servo arm 90 degrees
    digitalWrite(11, HIGH);     // Turn on green LED
    delay(500);                 // Wait 5 seconds
    digitalWrite(11, LOW);      //Turn off green LED
    Serial.println("Wrong");    // If the password is incorrect...
    myservo.write(0);
    digitalWrite(12, HIGH);     // Turn on red LED
    delay(500)                  // Wait 5 seconds
    digitalWrite(12, LOW);      // Turn off red LED
Do you see the error here :
No? Look better...
The ':' should be a ';'
This line is missing a ';'.
After fixing the ':'/';' mixup and adding the missing ';' the sketch compiles for me.
Maybe your Keypad library is the wrong version? I have "Keypad by Mark Stanley, Alexander Brevig Version 3.1.1".
