So books I have on the topic:
Exploring Arduino
Programming Interactivity
Programimming Arduino Getting
Started with Sketches
Programming Arduino Next Steps Going Further with Sketches
Then I have Hacking Electronics loaned out to a friend but could get it back if needed.
So I have a Kia Soul and it has a pair of led speakers stock. Would I be able to split the wire before the LEDs and run another set for say under my seat/ dash? The reason I want to do this is because it has a control switch already built in with two modes music and mood. Music is color selectively and mood just cycles through some colors.
Then where the real work comes in is I want to make rgb underglow but can't use reds or blues. Would it be possible to preprogram a random mode that would skip over these? In a perfect world I want to be able to have Color select, music, and random color modes. Then have them all follow the rules of two modes street and full range where street avoids using colors that would get me pulled over.
I have been looking at:
And I would just cut these to size. For those led strips would I use arduino for pwm then run direct lines for voltage so that each LED would be wired to two wires? A 12v and then a port off of the arduino.
And onto the more advanced stuff. I found theses solar LED hubcaps that are controlled by a wireless controller.
Would it be possible to rig up a receiver to pick up the remotes input and then program it into the arduino? So that its all in one nice little chip vs having a remote and controller.
I have absolutely no experience with this I've had these books for like 3 years now but never really did anything with it.
I've looked through the LED chapters but nothing on 12v. The fourm was pretty vauge on the first few pages beside the fact I need multiple resistors in the circuit to not burn the LEDs. I would prefer to do this through the battery and not the cigarette lighter.
What arduino should I use I have a uno r3 and Leonardo on hand I have no problem getting others. Any idea on a better LED strip or is the one I have fine?
