Killer code?
I have been coding animations for my arduino powered LED cube recently and I seem to have come across a bit of code that killed my diecimila.
long Random;
////////////////0 1 2 3 4 5 6 7 8  9  10 11
//int pins[] = {2,3,4,5,6,7,8,9,10,11,12,13};
int pins[] = {2,6,10,3,7,13,4,8,12,5,9,11};
int time = 10;
int time2 = 250;
int time3 = 0;
int time4 = 100;
  pinMode(pins[0], OUTPUT); //2 g
  pinMode(pins[1], OUTPUT); //3 3
  pinMode(pins[2], OUTPUT); //4 6
  pinMode(pins[3], OUTPUT); //5 9
  pinMode(pins[4], OUTPUT); //6 g
  pinMode(pins[5], OUTPUT); //7 2
  pinMode(pins[6], OUTPUT); //8 5
  pinMode(pins[7], OUTPUT); //9 8
  pinMode(pins[8], OUTPUT); //10 g
  pinMode(pins[9], OUTPUT); //11 1
  pinMode(pins[10], OUTPUT); //12 4
  pinMode(pins[11], OUTPUT); //13 7
  //Serial.begin(9600);
//START Moving Walls
digitalWrite(pins[0], LOW);
digitalWrite(pins[1], HIGH);
digitalWrite(pins[2], HIGH);
int c = 3;
while(c<=9)
for(int l = 0; l<=2; l++) //Controls which layer is lit
for(int i =c; i < i+3; i++)
    digitalWrite(pins[i], HIGH);
    digitalWrite(pins[i], LOW);
 digitalWrite(pins[l], HIGH); //Increments layer in voltage
 if(l != 2)
 digitalWrite(pins[l+1], LOW);
c = c+3;
delay(time2);
if(c > 9)
  c=3;
//END Moving Walls
After running that bit of code my arduino has stopped accepting new uploads. It runs(with a quick flash of my LEDs) when I first power up the arduino, but I cannot do anything else. I just get the error stk500_recv(): programmer is not responding
So, was it my code that did it or did I just get a borked piece of hardware? I use very similar code in other animations(in fact I mostly just changed a timing variable I think). I'm on 10.5.4 with the latest arduino software.
You can't say something like
because i will always be less than i + 3. Instead do something like
for(int i =c; i < c + 3; i++)
This shouldn't kill your board though, try loading the blink example sketch, verifying it, then pressing the reset button on the Arduino right after you press the upload button (or at the same time?).
Gah, that makes perfect sense, I can't believe I didn't see that one.
I've tried loading up the default sketches and pressing the reset button, it still gives me the error. Right now the led on pin 13 just blinks like crazy, but it isn't the blink sketch.
Thanks for your help, I might try doing a bitbang burn of the bootloader later today if I can figure out how to set it all up.
