Kindly asking for help with 8 year old code LCD display
Hi, for a prop related project I found the code for Conway's game of life, run by an Arduino and displayed on a 20x4 LCD display. The code is 8 years now and doesn't wok with the newer I2C LCD connections; I tried to add the reference to the newer I2C display library, the code compiles and uploads but does nothing on screen;
This is the original code:
/* Conway's Game of Life
*  2012-05-26
*  Mike Szczys
*  jumptuck.com
*  CC-BY-SA
*  Hardware: Arduino and 20x4 character LCD
*  This program will play Conway's Game of Life
*  of a 20x4 character LCD. It uses custom characters
*  to divide each row in two for a total resolution of 20x8
*  REQUIRES:
*  LiquidCrystal library that is built into the Arduino IDE
*  TODO:
*  -Fix bug that generates garbage at column 0
*  -Add a button for more random input
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
/*Display buffer:
*  index 0-19 for characters left to right
*  -each column is a bye
*  -LSB is top row (four character rows, eight virtual rows)
char lifeboard[20] = {
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256),
  random(256)
// make some custom characters:
byte box_full[8] = {
  0b01110,
  0b01110,
  0b01110,
  0b00000,
  0b00000,
  0b01110,
  0b01110,
  0b01110
byte box_N[8] = {
  0b01110,
  0b01110,
  0b01110,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000
byte box_S[8] = {
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b00000,
  0b01110,
  0b01110,
  0b01110
void evolve() {
  //Setup a temporary game baord for the next generation
  unsigned char nextGeneration[20];
  for (unsigned char i=1; i<20; i++) nextGeneration[i] = 0;
  //Iterate through all current cells to calculate next generation
  for (unsigned char row=0; row<8; row++) {
    for (unsigned char col=0; col<20; col++) {
      //get state of this cell
      unsigned char thisCell = 0;
      if (lifeboard[col]&(1<<row)) thisCell = 1;
      //===start check of all neighbors===
      unsigned char neighbor_count = 0;
      //get search coordinates
      unsigned char neighbor_cols[3] = {col-1, col, col+1};
      //fix wrap around for board
      if (col == 0) neighbor_cols[0] = 19;
      if (col == 19) neighbor_cols[2] = 0;
      unsigned char neighbor_rows[3] = {row-1, row, row+1};
      if (row == 0) neighbor_rows[0] = 7;
      if (row == 7) neighbor_rows[2] = 0;
      for (unsigned char i=0; i<3; i++) {
        for (unsigned char j=0; j<3; j++) {
          if (lifeboard[neighbor_cols[i]]&(1<<neighbor_rows[j])) neighbor_count += 1;
      //Subtract current cell as it was counted as a neighbor
      neighbor_count -= thisCell;
      //===end check of all neighbors===
      //use neighbor_count to check Conway's Game of Life rules
      if (thisCell) {
        if ((neighbor_count < 2) || (neighbor_count > 3)) nextGeneration[col] &= ~(1<<row);
        else nextGeneration[col] |= (1<<row);
      else if (neighbor_count == 3) nextGeneration[col] |= 1<<row;
  //copy all temp values to the screen game board
  for (unsigned char i=0; i<20; i++) {
    lifeboard[i] = nextGeneration[i];
  lcd.createChar(0, box_full);
  lcd.createChar(1, box_N);
  lcd.createChar(2, box_S);
  lcd.begin(20, 4);
  for (unsigned char row=0; row<4; row++){
    lcd.setCursor(0, row);
    unsigned char v_row1 = row*2;
    unsigned char v_row2 = v_row1 + 1;
      if ((lifeboard[col]&(1<<v_row1)) && (lifeboard[col]&(1<<v_row2))) lcd.write((byte)0);
      else if (lifeboard[col]&(1<<v_row1)) lcd.write((byte)1);
      else if (lifeboard[col]&(1<<v_row2)) lcd.write((byte)2);
      else lcd.print(' ');
  evolve();
  delay(300);
  //lcd.print(millis()/1000);
Anybody want to take a look at it and tell me if its feasable to update to today's standards?
Worst case scenario: I'll take the I2C board out of the equation and wire the LCD directly to the Arduino. It's messier than 4 wires, but hey might work that way.
Sad Coincidence: Just learned that English Mathematician John Conway died of COVID19 related complications, April the 11th at the age of 82.
I would recommend that you use the currently best available library for the i2c lcd modules which is Bill Perry's hd44780.h. It is available through the library manager. It will auto configure the i2c address and the pin configuration. There is a comprehensive diagnostic sketch as part of the library if there are any issues.
There is reference material at
https://github.com/duinoWitchery/hd44780
Install the library, and this sketch should work with your device.
#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h> // include i/o class header
hd44780_I2Cexp lcd; // declare lcd object: auto locate & config display for hd44780 chip
  // initialize LCD with number of columns and rows:
  lcd.begin(20, 4);
  // Print a message to the LCD
  lcd.print("Hello, World!");
  lcd.setCursor(0, 1);
  lcd.print(millis() / 1000);
Thanks for the suggestion, I'll give it a try. I2C is so much nicer instead of the wire mess.
