kindly explain this part of code??
//////////////////////////////////////// Read an ID from EEPROM //////////////////////////////
void readID( uint8_t number )
uint8_t start = (number*8 ) + 2;
for ( uint8_t i = 0; i < 4; i++ )
storedCard[i] = EEPROM.read(start + i);
storedPass[i] = EEPROM.read(start + i + 4);
Same as http://forum.arduino.cc/index.php?topic=598124.
yes but i need a definite explanation as on what are the iterations about??
You may (not) have noticed that your code turned italic in the middle. That means that in there somewhere there's a [i] as part of your sketch that browsers take to mean "turn on italics". So perhaps you should put your code in tags
[code]sketch goes here [/code]
so people can actually read it properly?
hannahrj:
just a wild guess here, but you should know this :slight_smile:
Are the IDs stored 4 byte wide?
If yes, then there’s you answer to “what are the iterations about”
Looks like nonsense to me
Are you sure that it shouldn't be
    storedPass[i + 4] = EEPROM.read(start + i + 4);
EDIT : Ignore the above. I read the code wrongly
void readID( uint8_t number )                 //nunber = 1
   uint8_t start = (number*8 ) + 2;         //statrt = 10
     //contents of EEPROM locations 10 to 13 are stored into locations storedCaed[0] to storedCard[3]
     //of the array named [b]byte storedCard[][/b].
      //contents of EEPROM locations 14 to 17 are are stored into locations storedPass[0] to storedPass[3]
      //of the array named [b]byte storedPass[][/b].
GolamMostafa:
Formatting tags inside [code] [/code] don't work.
rainbow_rings:
I am lucky that these are under comments.
for ( uint8_t i = 0; i < 4; i++ ) {
So the code thinks that there is an “id” stored in the EEPROM starting at “start”, that consists of 4 bytes of “Card” and then 4 bytes of “Pass.”
It “cleverly” uses a single for loop that runs 4 times, each time reading one byte of Card and one byte of Pass (which is 4 bytes further on in the EEPROM.) It probably saves about a dozen bytes of code over the more obvious technique of reading first the Card and then the Pass. Grr.
or rewrite it from scratch with a simple struct{}
Then use EEPROM.put & get to save all that work.
lastchancename:
When the Op's title is: "kindly explain this part of code??", what should we possibly explain?
GolamMostafa:
    //of the array named byte storedCard[].
      //of the array named byte storedPass[].
Thank you that helped a lot
