Knight rider
const int lowestPin = 9;
const int highestPin = 13;
  // set pins 2 through 13 as outputs:
  for (int thisPin =lowestPin; thisPin <= highestPin; thisPin++) {
    pinMode(thisPin, OUTPUT);
  for (int thisPin =lowestPin; thisPin <= highestPin; thisPin++){
    digitalWrite(thisPin, thisPin);
    delay(100);
It just lights them up (of course not all of them in one time which is the thing i want) and they stay on so how do i make it repeat?
You need to look at the documentation for the digitalWrite() function, to see what the arguments are supposed to be. Only one is a pin NUMBER.
and they stay on
Because you don't turn them off.
There must be about 800 million variations of this code floating around. I find it a bit difficult to believe that you can't find code that works.
There must be about 800 million variations of this code floating around. I find it a bit difficult to believe that you can't find code that works. [/quote] Well you see i like to do it myself not copy paste from the internet
Well luckily in this case, you can just copy and paste your own code. digitalWrite's second parameter should be HIGH or LOW. Fix that and then copy & paste your for loop so you have one version setting the leds HIGH followed by one that sets them LOW.
