I have several Nano clones laying around. They are about 10 years old. I had some fun with these using Windows XP and third party drivers, back then.
By today's standards, does Arduino IDE support these in either Windows 10/11 or Linux (Raspberry Pi)?
Or should I throw them away?
Why wouldn't they still work?
I program my Nanos regularly with IDE 1.8.19, and have heard of no reason why the present IDE, 2.3.2 or thereabouts I believe, would not do just as well. You do have to load the extra COM driver, but that's usually trivial. There have been a few Windows Updates that have loaded a more recent, flaky, driver, but there are threads on this forum outlining how to overcome that.
If you're about to throw them out, I'd give you an address you can mail them to, but it's likely the postage would cost more than I can buy them for at AliExpress, so there's that.
Long story short, they may on Windows. I'm developing on a Raspberry Pi but didn't want to get into a bunch of hacking. I was looking for, Known support.
I tried connecting with my Pi 4 and got this:
Arduino: 1.8.19 (Linux), Board: "Arduino/Genuino Uno"
Sketch uses 8422 bytes (26%) of program storage space. Maximum is 32256 bytes.
Global variables use 765 bytes (37%) of dynamic memory, leaving 1283 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
An error occurred while uploading the sketch
option enabled in File -> Preferences.
I assumed it was from unsupported drivers.
But, it thinks it's talking to an Uno...
Maybe, enable verbose reporting...
It seems you are on to something:
/opt/arduino-1.8.19/arduino-builder -dump-prefs -logger=machine -hardware /opt/arduino-1.8.19/hardware -hardware /home/pi/.arduino15/packages -tools /opt/arduino-1.8.19/tools-builder -tools /opt/arduino-1.8.19/hardware/tools/avr -tools /home/pi/.arduino15/packages -built-in-libraries /opt/arduino-1.8.19/libraries -libraries /home/pi/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10819 -build-path /tmp/arduino_build_370816 -warnings=none -build-cache /tmp/arduino_cache_250423 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/pi/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/home/pi/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=/home/pi/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/home/pi/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -verbose /home/pi/Arduino/GeocacheShaveAndAHaircut_Servo_RevB/GeocacheShaveAndAHaircut_Servo_RevB.ino
/opt/arduino-1.8.19/arduino-builder -compile -logger=machine -hardware /opt/arduino-1.8.19/hardware -hardware /home/pi/.arduino15/packages -tools /opt/arduino-1.8.19/tools-builder -tools /opt/arduino-1.8.19/hardware/tools/avr -tools /home/pi/.arduino15/packages -built-in-libraries /opt/arduino-1.8.19/libraries -libraries /home/pi/Arduino/libraries -fqbn=arduino:avr:uno -vid-pid=1A86_7523 -ide-version=10819 -build-path /tmp/arduino_build_370816 -warnings=none -build-cache /tmp/arduino_cache_250423 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/pi/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/home/pi/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=/home/pi/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/home/pi/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -verbose /home/pi/Arduino/GeocacheShaveAndAHaircut_Servo_RevB/GeocacheShaveAndAHaircut_Servo_RevB.ino
Using board 'uno' from platform in folder: /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23
Using core 'arduino' from platform in folder: /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23
Detecting libraries used...
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/standard /tmp/arduino_build_370816/sketch/GeocacheShaveAndAHaircut_Servo_RevB.ino.cpp -o /dev/null
Alternatives for LiquidCrystal.h: [LiquidCrystal@1.0.7]
ResolveLibrary(LiquidCrystal.h)
-> candidates: [LiquidCrystal@1.0.7]
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/standard -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src /tmp/arduino_build_370816/sketch/GeocacheShaveAndAHaircut_Servo_RevB.ino.cpp -o /dev/null
Alternatives for Servo.h: [Servo@1.1.8]
ResolveLibrary(Servo.h)
-> candidates: [Servo@1.1.8]
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/standard -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /tmp/arduino_build_370816/sketch/GeocacheShaveAndAHaircut_Servo_RevB.ino.cpp -o /dev/null
Using cached library dependencies for file: /opt/arduino-1.8.19/libraries/LiquidCrystal/src/LiquidCrystal.cpp
Using cached library dependencies for file: /opt/arduino-1.8.19/libraries/Servo/src/avr/Servo.cpp
Using cached library dependencies for file: /opt/arduino-1.8.19/libraries/Servo/src/mbed/Servo.cpp
Using cached library dependencies for file: /opt/arduino-1.8.19/libraries/Servo/src/megaavr/Servo.cpp
Using cached library dependencies for file: /opt/arduino-1.8.19/libraries/Servo/src/nrf52/Servo.cpp
Using cached library dependencies for file: /opt/arduino-1.8.19/libraries/Servo/src/sam/Servo.cpp
Using cached library dependencies for file: /opt/arduino-1.8.19/libraries/Servo/src/samd/Servo.cpp
Using cached library dependencies for file: /opt/arduino-1.8.19/libraries/Servo/src/stm32f4/Servo.cpp
Generating function prototypes...
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/standard -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /tmp/arduino_build_370816/sketch/GeocacheShaveAndAHaircut_Servo_RevB.ino.cpp -o /tmp/arduino_build_370816/preproc/ctags_target_for_gcc_minus_e.cpp
/opt/arduino-1.8.19/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_370816/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/standard -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /tmp/arduino_build_370816/sketch/GeocacheShaveAndAHaircut_Servo_RevB.ino.cpp -o /tmp/arduino_build_370816/sketch/GeocacheShaveAndAHaircut_Servo_RevB.ino.cpp.o
Compiling libraries...
Compiling library "LiquidCrystal"
Using previously compiled file: /tmp/arduino_build_370816/libraries/LiquidCrystal/LiquidCrystal.cpp.o
Compiling library "Servo"
Using previously compiled file: /tmp/arduino_build_370816/libraries/Servo/avr/Servo.cpp.o
Using previously compiled file: /tmp/arduino_build_370816/libraries/Servo/mbed/Servo.cpp.o
Using previously compiled file: /tmp/arduino_build_370816/libraries/Servo/megaavr/Servo.cpp.o
Using previously compiled file: /tmp/arduino_build_370816/libraries/Servo/nrf52/Servo.cpp.o
Using previously compiled file: /tmp/arduino_build_370816/libraries/Servo/sam/Servo.cpp.o
Using previously compiled file: /tmp/arduino_build_370816/libraries/Servo/samd/Servo.cpp.o
Using previously compiled file: /tmp/arduino_build_370816/libraries/Servo/stm32f4/Servo.cpp.o
Compiling core...
Using precompiled core: /tmp/arduino_cache_250423/core/core_arduino_avr_uno_f56d830a8785e3af98860af0323fe2ec.a
Linking everything together...
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /tmp/arduino_build_370816/GeocacheShaveAndAHaircut_Servo_RevB.ino.elf /tmp/arduino_build_370816/sketch/GeocacheShaveAndAHaircut_Servo_RevB.ino.cpp.o /tmp/arduino_build_370816/libraries/LiquidCrystal/LiquidCrystal.cpp.o /tmp/arduino_build_370816/libraries/Servo/avr/Servo.cpp.o /tmp/arduino_build_370816/libraries/Servo/mbed/Servo.cpp.o /tmp/arduino_build_370816/libraries/Servo/megaavr/Servo.cpp.o /tmp/arduino_build_370816/libraries/Servo/nrf52/Servo.cpp.o /tmp/arduino_build_370816/libraries/Servo/sam/Servo.cpp.o /tmp/arduino_build_370816/libraries/Servo/samd/Servo.cpp.o /tmp/arduino_build_370816/libraries/Servo/stm32f4/Servo.cpp.o /tmp/arduino_build_370816/../arduino_cache_250423/core/core_arduino_avr_uno_f56d830a8785e3af98860af0323fe2ec.a -L/tmp/arduino_build_370816 -lm
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino_build_370816/GeocacheShaveAndAHaircut_Servo_RevB.ino.elf /tmp/arduino_build_370816/GeocacheShaveAndAHaircut_Servo_RevB.ino.eep
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino_build_370816/GeocacheShaveAndAHaircut_Servo_RevB.ino.elf /tmp/arduino_build_370816/GeocacheShaveAndAHaircut_Servo_RevB.ino.hex
Using library LiquidCrystal at version 1.0.7 in folder: /opt/arduino-1.8.19/libraries/LiquidCrystal
Using library Servo at version 1.1.8 in folder: /opt/arduino-1.8.19/libraries/Servo
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-size -A /tmp/arduino_build_370816/GeocacheShaveAndAHaircut_Servo_RevB.ino.elf
So apparently it was my mistake on board selection. I chose Nano and now my output is:
Arduino: 1.8.19 (Linux), Board: "Arduino Nano, ATmega328P"
/opt/arduino-1.8.19/arduino-builder -dump-prefs -logger=machine -hardware /opt/arduino-1.8.19/hardware -hardware /home/pi/.arduino15/packages -tools /opt/arduino-1.8.19/tools-builder -tools /opt/arduino-1.8.19/hardware/tools/avr -tools /home/pi/.arduino15/packages -built-in-libraries /opt/arduino-1.8.19/libraries -libraries /home/pi/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10819 -build-path /tmp/arduino_build_370816 -warnings=none -build-cache /tmp/arduino_cache_250423 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/pi/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/home/pi/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=/home/pi/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/home/pi/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -verbose /home/pi/Arduino/GeocacheShaveAndAHaircut_Servo_RevB/GeocacheShaveAndAHaircut_Servo_RevB.ino
/opt/arduino-1.8.19/arduino-builder -compile -logger=machine -hardware /opt/arduino-1.8.19/hardware -hardware /home/pi/.arduino15/packages -tools /opt/arduino-1.8.19/tools-builder -tools /opt/arduino-1.8.19/hardware/tools/avr -tools /home/pi/.arduino15/packages -built-in-libraries /opt/arduino-1.8.19/libraries -libraries /home/pi/Arduino/libraries -fqbn=arduino:avr:nano:cpu=atmega328 -vid-pid=1A86_7523 -ide-version=10819 -build-path /tmp/arduino_build_370816 -warnings=none -build-cache /tmp/arduino_cache_250423 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.avrdude.path=/home/pi/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avrdude-6.3.0-arduino14.path=/home/pi/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14 -prefs=runtime.tools.avr-gcc.path=/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.avr-gcc-5.4.0-atmel3.6.1-arduino2.path=/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2 -prefs=runtime.tools.arduinoOTA.path=/home/pi/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/home/pi/.arduino15/packages/arduino/tools/arduinoOTA/1.2.1 -verbose /home/pi/Arduino/GeocacheShaveAndAHaircut_Servo_RevB/GeocacheShaveAndAHaircut_Servo_RevB.ino
Using board 'nano' from platform in folder: /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /tmp/arduino_build_370816/sketch/GeocacheShaveAndAHaircut_Servo_RevB.ino.cpp -o /dev/null
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src /tmp/arduino_build_370816/sketch/GeocacheShaveAndAHaircut_Servo_RevB.ino.cpp -o /dev/null
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /tmp/arduino_build_370816/sketch/GeocacheShaveAndAHaircut_Servo_RevB.ino.cpp -o /dev/null
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/LiquidCrystal/src/LiquidCrystal.cpp -o /dev/null
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/Servo/src/avr/Servo.cpp -o /dev/null
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/Servo/src/mbed/Servo.cpp -o /dev/null
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/Servo/src/megaavr/Servo.cpp -o /dev/null
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/Servo/src/nrf52/Servo.cpp -o /dev/null
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/Servo/src/sam/Servo.cpp -o /dev/null
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/Servo/src/samd/Servo.cpp -o /dev/null
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/Servo/src/stm32f4/Servo.cpp -o /dev/null
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /tmp/arduino_build_370816/sketch/GeocacheShaveAndAHaircut_Servo_RevB.ino.cpp -o /tmp/arduino_build_370816/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /tmp/arduino_build_370816/sketch/GeocacheShaveAndAHaircut_Servo_RevB.ino.cpp -o /tmp/arduino_build_370816/sketch/GeocacheShaveAndAHaircut_Servo_RevB.ino.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/LiquidCrystal/src/LiquidCrystal.cpp -o /tmp/arduino_build_370816/libraries/LiquidCrystal/LiquidCrystal.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/Servo/src/avr/Servo.cpp -o /tmp/arduino_build_370816/libraries/Servo/avr/Servo.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/Servo/src/mbed/Servo.cpp -o /tmp/arduino_build_370816/libraries/Servo/mbed/Servo.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/Servo/src/megaavr/Servo.cpp -o /tmp/arduino_build_370816/libraries/Servo/megaavr/Servo.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/Servo/src/nrf52/Servo.cpp -o /tmp/arduino_build_370816/libraries/Servo/nrf52/Servo.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/Servo/src/sam/Servo.cpp -o /tmp/arduino_build_370816/libraries/Servo/sam/Servo.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/Servo/src/samd/Servo.cpp -o /tmp/arduino_build_370816/libraries/Servo/samd/Servo.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs -I/opt/arduino-1.8.19/libraries/LiquidCrystal/src -I/opt/arduino-1.8.19/libraries/Servo/src /opt/arduino-1.8.19/libraries/Servo/src/stm32f4/Servo.cpp -o /tmp/arduino_build_370816/libraries/Servo/stm32f4/Servo.cpp.o
Compiling core...
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc -c -g -x assembler-with-cpp -flto -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/wiring_pulse.S -o /tmp/arduino_build_370816/core/wiring_pulse.S.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/WInterrupts.c -o /tmp/arduino_build_370816/core/WInterrupts.c.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/wiring_analog.c -o /tmp/arduino_build_370816/core/wiring_analog.c.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/hooks.c -o /tmp/arduino_build_370816/core/hooks.c.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/wiring.c -o /tmp/arduino_build_370816/core/wiring.c.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/wiring_digital.c -o /tmp/arduino_build_370816/core/wiring_digital.c.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/wiring_pulse.c -o /tmp/arduino_build_370816/core/wiring_pulse.c.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc -c -g -Os -w -std=gnu11 -ffunction-sections -fdata-sections -MMD -flto -fno-fat-lto-objects -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/wiring_shift.c -o /tmp/arduino_build_370816/core/wiring_shift.c.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/HardwareSerial.cpp -o /tmp/arduino_build_370816/core/HardwareSerial.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/CDC.cpp -o /tmp/arduino_build_370816/core/CDC.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/HardwareSerial1.cpp -o /tmp/arduino_build_370816/core/HardwareSerial1.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/HardwareSerial0.cpp -o /tmp/arduino_build_370816/core/HardwareSerial0.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/HardwareSerial2.cpp -o /tmp/arduino_build_370816/core/HardwareSerial2.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/IPAddress.cpp -o /tmp/arduino_build_370816/core/IPAddress.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/HardwareSerial3.cpp -o /tmp/arduino_build_370816/core/HardwareSerial3.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/PluggableUSB.cpp -o /tmp/arduino_build_370816/core/PluggableUSB.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/Print.cpp -o /tmp/arduino_build_370816/core/Print.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/Stream.cpp -o /tmp/arduino_build_370816/core/Stream.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/Tone.cpp -o /tmp/arduino_build_370816/core/Tone.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/USBCore.cpp -o /tmp/arduino_build_370816/core/USBCore.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/WMath.cpp -o /tmp/arduino_build_370816/core/WMath.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/WString.cpp -o /tmp/arduino_build_370816/core/WString.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/abi.cpp -o /tmp/arduino_build_370816/core/abi.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/main.cpp -o /tmp/arduino_build_370816/core/main.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10819 -DARDUINO_AVR_NANO -DARDUINO_ARCH_AVR -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino -I/home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/variants/eightanaloginputs /home/pi/.arduino15/packages/arduino/hardware/avr/1.6.23/cores/arduino/new.cpp -o /tmp/arduino_build_370816/core/new.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/wiring_pulse.S.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/WInterrupts.c.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/hooks.c.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/wiring.c.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/wiring_analog.c.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/wiring_digital.c.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/wiring_pulse.c.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/wiring_shift.c.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/CDC.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/HardwareSerial.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/HardwareSerial0.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/HardwareSerial1.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/HardwareSerial2.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/HardwareSerial3.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/IPAddress.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/PluggableUSB.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/Print.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/Stream.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/Tone.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/USBCore.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/WMath.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/WString.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/abi.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/main.cpp.o
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc-ar rcs /tmp/arduino_build_370816/core/core.a /tmp/arduino_build_370816/core/new.cpp.o
Archiving built core (caching) in: /tmp/arduino_cache_250423/core/core_arduino_avr_nano_cpu_atmega328_f56d830a8785e3af98860af0323fe2ec.a
/home/pi/.arduino15/packages/arduino/tools/avr-gcc/5.4.0-atmel3.6.1-arduino2/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o /tmp/arduino_build_370816/GeocacheShaveAndAHaircut_Servo_RevB.ino.elf /tmp/arduino_build_370816/sketch/GeocacheShaveAndAHaircut_Servo_RevB.ino.cpp.o /tmp/arduino_build_370816/libraries/LiquidCrystal/LiquidCrystal.cpp.o /tmp/arduino_build_370816/libraries/Servo/avr/Servo.cpp.o /tmp/arduino_build_370816/libraries/Servo/mbed/Servo.cpp.o /tmp/arduino_build_370816/libraries/Servo/megaavr/Servo.cpp.o /tmp/arduino_build_370816/libraries/Servo/nrf52/Servo.cpp.o /tmp/arduino_build_370816/libraries/Servo/sam/Servo.cpp.o /tmp/arduino_build_370816/libraries/Servo/samd/Servo.cpp.o /tmp/arduino_build_370816/libraries/Servo/stm32f4/Servo.cpp.o /tmp/arduino_build_370816/core/core.a -L/tmp/arduino_build_370816 -lm
Sketch uses 8422 bytes (27%) of program storage space. Maximum is 30720 bytes.
Still digesting this...
Hi @sthomas3rd . A program called a "bootloader " is stored in a special area of memory in the Nano board's microcontroller. The classic Nano (as well as its 3rd party derivatives) have been manufactured with two different types of bootloader installed.
You must configure the Tools > Processor menu in Arduino IDE according to which bootloader is installed on your Nano . Having the incorrect configuration selected in this menu is one of the potential causes of uploads failing with the "avrdude: stk500_recv(): programmer is not responding" error.
The fact that your Nanos are from 10 years ago tells us that your Nano board has the "old" bootloader installed (the "new" bootloader was introduced in 2018).
I can see from the verbose upload output that you have Arduino IDE incorrectly configured for use with your Nano boards, which have the "old" bootloader.
Select Tools > Processor > ATmega328P (Old Bootloader) from the Arduino IDE menus and then try uploading again.
Hopefully this time the upload will finish successfully.
Thank you so much Mr. @ptillisch ! You hit nail right on the head. This old guy can continue to use his old equipment.
@ptillisch , and thank you for the detailed explanation. It's very informative.
You are welcome. I'm glad it is working now.
Regards, Per
system
Closed
July 19, 2025, 2:32am
12
