Knock sensor help
Hello guys.
I’m a design student and that’s my second experience with arduino. I manage to connect all the stuff I’m using in correct order but desperately need help with the code.
I’m using:
  1. Arduino duemilanove for prototyping (originally will use nano)
  2. Piezo buzzer as a sensor (plugged at analog pin 0)
  3. 10 LEDs ( pins from 4 to 13)
The effect I’m trying to achieve:
Knock the piezo buzzer → Leds fade in (in certain order 4 to 13) → delay (20) → Leds fade out → stop till the next knock
My Leds fade in/out in loop but even here not all Leds fading… some of them just turn on/off.
That’s the code I’m using.
int ledPin4 = 4;
int ledPin5 = 5;
int ledPin6 = 6;
int ledPin7 = 7;
int ledPin8 = 8;
int ledPin9 = 9;
int ledPin10 = 10;
int ledPin11 = 11;
int ledPin12 = 12;
int ledPin13 = 13;
void setup()  {
void loop()  {
  for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
    analogWrite(ledPin4, fadeValue);
    delay(20);
    analogWrite(ledPin5, fadeValue);
    delay(20);
    analogWrite(ledPin6, fadeValue);
    delay(20);
    analogWrite(ledPin7, fadeValue);
    delay(20);
    analogWrite(ledPin8, fadeValue);
    delay(20);
    analogWrite(ledPin9, fadeValue);
    delay(20);
    analogWrite(ledPin10, fadeValue);
    delay(20);
    analogWrite(ledPin11, fadeValue);
    delay(20);
    analogWrite(ledPin12, fadeValue);
    delay(20);
    analogWrite(ledPin13, fadeValue);
    delay(20);
for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
    delay(20);
    delay(20);
    delay(20);
    delay(20);
    delay(20);
    delay(20);
    delay(20);
    delay(20);
    delay(20);
    delay(20);
How to make all Leds fade in/out and add the code for piezo sensor?
Could someone please help me out with the code if possible. Thanks guys.
Please modify your post (there is a button on the right),
select the code
press the # button above the smileys
and your code will look much better!
Learn about arrays - http://arduino.cc/en/Tutorial/Array - http://arduino.cc/it/Reference/Array -
That will make your code 5x smaller
sanulchik:
... but even here not all Leds fading... some of them just turn on/off.
Check out the documentation for analogWrite. In particular this statement:
... this function works on pins 3, 5, 6, 9, 10, and 11.
Thanks for reply.
Is there any chance to make it work on all pins (4-13)?
Do you want them to fade together or individually?
You could make a loop that turns them on and off. The looping is pretty fast, and if you do it fast enough you won't notice any flicker.
