Hej!
Håller på med ett simon says spel med display.
Vill lägga in ett meddelade när man vunnit. Men vet inte vart jag riktigt ska lägga in den i koden och vad man ska skriva för att det ska funka.
några tips?
Translation from Swedish via Google Translate
Hey! Is working on a simon says game with display. Want to post a message when you have won. But I do not know where I should really put it in the code and what to write for it to work. some tips?
du kan börja med att posta koden här ...
you could start by posting the code here....
#define led7 7 //white button led
#define led6 6 // green button led
#define led5 5 // red button led
#define led8 8 // blue button led
#define button7 led7 + 4 //white button
#define button6 led6 + 4 // green button
#define button5 led5 + 4 // red button
#define button8 led8 + 4 //blue button
#define levelsInGame 10
#define buzzer 3
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 32 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
//create an array for this game
int simonSaid[levelsInGame]; //initialise the array
// the setup function runs once when you press reset or power the board
// initialize digital pins as outputs for LEDS in the buttons.
pinMode(led7, OUTPUT);
pinMode(led6, OUTPUT);
pinMode(led5, OUTPUT);
pinMode(led8, OUTPUT);
digitalWrite(led7, LOW);
digitalWrite(led6, LOW);
digitalWrite(led5, LOW);
digitalWrite(led8, LOW);
pinMode(button7, INPUT_PULLUP); // set the button pins as inputs
pinMode(button6, INPUT_PULLUP);
pinMode(button5, INPUT_PULLUP);
pinMode(button8, INPUT_PULLUP);
randomSeed(analogRead(0)); //make our random numbers more random
// populate the array with random 'colours'
for (int i = 0; i <= levelsInGame; i++) {
simonSaid[i] = random(5, 9);
for(int j = 0; j < levelsInGame; j++) //Print this array to serial monitor
Serial.println(simonSaid[j]);
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) { // Address 0x3C for 128x32
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
display.clearDisplay();
display.setTextSize(2); // Draw 2X-scale text
display.setTextColor(WHITE);
display.setCursor(1, 0);
display.println("Simon Says");
display.setTextSize(1); // Draw 1X-scale text
display.println(" by ");
display.println("tinyurl.com/y2llr32t");
display.display(); // Show text
delay(2000);
// the loop function runs over and over again forever
bool gameOver = 0;
while (gameOver == 0) {
for (int i = 1; i < (levelsInGame + 1); i++) { // for each level
Serial.print("Level ");
Serial.println(i);
if (i < 10){
display.clearDisplay(); //print level on screen
display.setTextSize(3); // Draw 3X-scale text
display.print("Level ");
display.println(i);
delay(400);
display.clearDisplay(); //print level on screen in smaller text
display.print(" Level ");
display.println(i);
delay(400);
for (int g = 0; g < i; g++) { //play the colours through to that level
Serial.print("Colour number ");
Serial.print(g + 1);
Serial.print(" in this sequance is the button on D");
Serial.println(simonSaid[g]);
digitalWrite(simonSaid[g], HIGH);
playBuzzer(simonSaid[g]);
delay(200);
digitalWrite(simonSaid[g], LOW);
delay(50);
for (int g = 0; g < i; g++) { //check the colours you enter for that level
Serial.print("Press the correct button for number ");
Serial.print(" in Simon's sequance which should be the one connected to pin D");
int sensorButton7 = 1;
int sensorButton6 = 1;
int sensorButton5 = 1;
int sensorButton8 = 1;
int buttonPressed = 0; //a button that does not exist
while (sensorButton5 == HIGH && sensorButton6 == HIGH && sensorButton7 == HIGH && sensorButton8 == HIGH) { //until a button is pressed keep checking all of them
sensorButton7 = digitalRead(button7);
//Serial.print("Sensor button 0 = ");
//Serial.println(sensorButton0);
sensorButton6 = digitalRead(button6);
//Serial.print("Sensor button 1 = ");
//Serial.println(sensorButton1);
sensorButton5 = digitalRead(button5);
//Serial.print("Sensor button 2 = ");
//Serial.println(sensorButton2);
sensorButton8 = digitalRead(button8);
//Serial.print("Sensor button 3 = ");
// Serial.println(sensorButton3);
delay(200); // a kind of debounce - maybe later swap it for a check that all buttons have been depressed for 100ms?
//record which one was pressed
if (sensorButton7 == 0) {
buttonPressed = 7;
else if (sensorButton6 == 0) {
buttonPressed = 6;
else if (sensorButton5 == 0) {
buttonPressed = 5;
else {
buttonPressed = 8;
Serial.print("Button that was pressed is = "); //print out the pressed button
Serial.println(buttonPressed);
digitalWrite(buttonPressed, HIGH); //turn on the button light
playBuzzer(buttonPressed); //make the sound of the button pressed - right or wrong
digitalWrite(buttonPressed, LOW); //turn off button light
//check to see if it is what should be pressed
if (buttonPressed == (simonSaid[g])) {
Serial.println("Correct button - well done");
else {
Serial.println("Wrong button was pressed.");
gameOver = 1;
Serial.println("Game finished - sorry. Better luck next time.");
display.println("GAME OVER");
display.print("at lvl ");
display.print(i);
display.display(); // Show initial text
//display.startscrollleft(0x00, 0x0F);
tone(buzzer, 350); //play game over low tone on buzzer
digitalWrite(led7, HIGH); //turn on all the lights
digitalWrite(led6, HIGH);
digitalWrite(led5, HIGH);
digitalWrite(led8, HIGH);
delay(2000);
noTone(buzzer);
digitalWrite(led7, LOW); //turn oFF all the lights
delay(2000);
softReset();
void softReset() {
asm volatile (" jmp 0");
void playBuzzer(int button) {
if (button == 5) {
tone(buzzer, 950);
delay(300);
noTone(buzzer);
else if (button == 6) {
tone(buzzer, 850);
delay(300);
noTone(buzzer);
else if (button == 7) {
tone(buzzer, 750);
delay(300);
noTone(buzzer);
else if (button == 8) {
tone(buzzer, 650);
delay(300);
noTone(buzzer);
