Kompilierung fehlgeschlagen
Beim Versuch zu kompilieren wird ein Fehler gem. Fehlerprotokoll angezeigt. Mir ist nicht klar, was hier zu ändern ist.
#include <EEPROM.h>
#include <EEPROM.h>
    This file is part of Repetier-Firmware.
    Repetier-Firmware is free software: you can redistribute it and/or modify
    it under the terms of the GNU General Public License as published by
    the Free Software Foundation, either version 3 of the License, or
    (at your option) any later version.
    Repetier-Firmware is distributed in the hope that it will be useful,
    but WITHOUT ANY WARRANTY; without even the implied warranty of
    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
    GNU General Public License for more details.
    You should have received a copy of the GNU General Public License
    along with Repetier-Firmware.  If not, see <http://www.gnu.org/licenses/>.
    This firmware is a nearly complete rewrite of the sprinter firmware
    by kliment (https://github.com/kliment/Sprinter)
    which based on Tonokip RepRap firmware rewrite based off of Hydra-mmm firmware.
  Functions in this file are used to communicate using ascii or repetier protocol.
#ifndef MOTION_H_INCLUDED
#define MOTION_H_INCLUDED
/** Marks the first step of a new move */
#define FLAG_WARMUP 1
#define FLAG_NOMINAL 2
#define FLAG_DECELERATING 4
#define FLAG_ACCELERATION_ENABLED 8
#define FLAG_CHECK_ENDSTOPS 16
#define FLAG_SKIP_ACCELERATING 32
#define FLAG_SKIP_DEACCELERATING 64
#define FLAG_BLOCKED 128
/** Are the step parameter computed */
#define FLAG_JOIN_STEPPARAMS_COMPUTED 1
/** The right speed is fixed. Don't check this block or any block to the left. */
#define FLAG_JOIN_END_FIXED 2
/** The left speed is fixed. Don't check left block. */
#define FLAG_JOIN_START_FIXED 4
/** Start filament retraction at move start */
#define FLAG_JOIN_START_RETRACT 8
/** Wait for filament pushback, before ending move */
#define FLAG_JOIN_END_RETRACT 16
/** Disable retract for this line */
#define FLAG_JOIN_NO_RETRACT 32
/** Wait for the extruder to finish it's up movement */
#define FLAG_JOIN_WAIT_EXTRUDER_UP 64
/** Wait for the extruder to finish it's down movement */
#define FLAG_JOIN_WAIT_EXTRUDER_DOWN 128
// Printing related data
#if NONLINEAR_SYSTEM
// Allow the delta cache to store segments for every line in line cache. Beware this gets big ... fast.
// DELTASEGMENTS_PER_PRINTLINE *
#define DELTA_CACHE_SIZE (DELTASEGMENTS_PER_PRINTLINE * PRINTLINE_CACHE_SIZE)
class PrintLine;
typedef struct
    flag8_t dir; 									///< Direction of delta movement.
    uint16_t deltaSteps[TOWER_ARRAY];   				    ///< Number of steps in move.
    inline void checkEndstops(PrintLine *cur,bool checkall);
    inline void setXMoveFinished()
        dir &= ~XSTEP;
    inline void setYMoveFinished()
        dir &= ~YSTEP;
    inline void setZMoveFinished()
        dir &= ~ZSTEP;
    inline void setXYMoveFinished()
        dir &= ~XY_STEP;
    inline bool isXPositiveMove()
        return (dir & X_STEP_DIRPOS) == X_STEP_DIRPOS;
    inline bool isXNegativeMove()
        return (dir & X_STEP_DIRPOS) == XSTEP;
    inline bool isYPositiveMove()
        return (dir & Y_STEP_DIRPOS) == Y_STEP_DIRPOS;
    inline bool isYNegativeMove()
        return (dir & Y_STEP_DIRPOS) == YSTEP;
    inline bool isZPositiveMove()
        return (dir & Z_STEP_DIRPOS) == Z_STEP_DIRPOS;
    inline bool isZNegativeMove()
        return (dir & Z_STEP_DIRPOS) == ZSTEP;
    inline bool isEPositiveMove()
        return (dir & E_STEP_DIRPOS) == E_STEP_DIRPOS;
    inline bool isENegativeMove()
        return (dir & E_STEP_DIRPOS) == ESTEP;
    inline bool isXMove()
        return (dir & XSTEP);
    inline bool isYMove()
        return (dir & YSTEP);
    inline bool isXOrYMove()
        return dir & XY_STEP;
    inline bool isZMove()
        return (dir & ZSTEP);
    inline bool isEMove()
        return (dir & ESTEP);
    inline bool isEOnlyMove()
        return (dir & XYZE_STEP)==ESTEP;
    inline bool isNoMove()
        return (dir & XYZE_STEP)==0;
    inline bool isXYZMove()
        return dir & XYZ_STEP;
    inline bool isMoveOfAxis(uint8_t axis)
        return (dir & (XSTEP<<axis));
    inline void setMoveOfAxis(uint8_t axis)
        dir |= XSTEP<<axis;
    inline void setPositiveMoveOfAxis(uint8_t axis)
        dir |= X_STEP_DIRPOS<<axis;
    inline void setPositiveDirectionForAxis(uint8_t axis)
        dir |= X_DIRPOS<<axis;
} DeltaSegment;
extern uint8_t lastMoveID;
#endif
class UIDisplay;
class PrintLine   // RAM usage: 24*4+15 = 113 Byte
    friend class UIDisplay;
#if CPU_ARCH==ARCH_ARM
    static volatile bool nlFlag;
#endif
public:
    static uint8_t linesPos; // Position for executing line movement
    static PrintLine lines[];
    static uint8_t linesWritePos; // Position where we write the next cached line move
    flag8_t joinFlags;
    volatile flag8_t flags;
private:
    flag8_t primaryAxis;
    int32_t timeInTicks;
    flag8_t halfStep;                  ///< 4 = disabled, 1 = halfstep, 2 = fulstep
    flag8_t dir;                       ///< Direction of movement. 1 = X+, 2 = Y+, 4= Z+, values can be combined.
    int32_t delta[E_AXIS_ARRAY];                  ///< Steps we want to move.
    int32_t error[E_AXIS_ARRAY];                  ///< Error calculation for Bresenham algorithm
    float speedX;                   ///< Speed in x direction at fullInterval in mm/s
    float speedY;                   ///< Speed in y direction at fullInterval in mm/s
    float speedZ;                   ///< Speed in z direction at fullInterval in mm/s
    float speedE;                   ///< Speed in E direction at fullInterval in mm/s
    float fullSpeed;                ///< Desired speed mm/s
    float invFullSpeed;             ///< 1.0/fullSpeed for fatser computation
    float accelerationDistance2;             ///< Real 2.0*distanceÜacceleration mm²/s²
    float maxJunctionSpeed;         ///< Max. junction speed between this and next segment
    float startSpeed;               ///< Staring speed in mm/s
    float endSpeed;                 ///< Exit speed in mm/s
    float minSpeed;
    float distance;
    uint8_t numDeltaSegments;		///< Number of delta segments left in line. Decremented by stepper timer.
    uint8_t moveID;					///< ID used to identify moves which are all part of the same line
    int32_t numPrimaryStepPerSegment;	///< Number of primary bresenham axis steps in each delta segment
    DeltaSegment segments[DELTASEGMENTS_PER_PRINTLINE];
#endif
    ticks_t fullInterval;     ///< interval at full speed in ticks/step.
    uint16_t accelSteps;        ///< How much steps does it take, to reach the plateau.
    uint16_t decelSteps;        ///< How much steps does it take, to reach the end speed.
    uint32_t accelerationPrim; ///< Acceleration along primary axis
    uint32_t fAcceleration;    ///< accelerationPrim*262144/F_CPU
    speed_t vMax;              ///< Maximum reached speed in steps/s.
    speed_t vStart;            ///< Starting speed in steps/s.
    speed_t vEnd;              ///< End speed in steps/s
#if USE_ADVANCE
#if ENABLE_QUADRATIC_ADVANCE
    int32_t advanceRate;               ///< Advance steps at full speed
    int32_t advanceFull;               ///< Maximum advance at fullInterval [steps*65536]
    int32_t advanceStart;
    int32_t advanceEnd;
#endif
    uint16_t advanceL;         ///< Recomputated L value
#endif
#ifdef DEBUG_STEPCOUNT
    int32_t totalStepsRemaining;
#endif
public:
    int32_t stepsRemaining;            ///< Remaining steps, until move is finished
    static PrintLine *cur;
    static volatile uint8_t linesCount; // Number of lines cached 0 = nothing to do
    inline bool areParameterUpToDate()
        return joinFlags & FLAG_JOIN_STEPPARAMS_COMPUTED;
    inline void invalidateParameter()
        joinFlags &= ~FLAG_JOIN_STEPPARAMS_COMPUTED;
    inline void setParameterUpToDate()
        joinFlags |= FLAG_JOIN_STEPPARAMS_COMPUTED;
    inline bool isStartSpeedFixed()
        return joinFlags & FLAG_JOIN_START_FIXED;
    inline void setStartSpeedFixed(bool newState)
        joinFlags = (newState ? joinFlags | FLAG_JOIN_START_FIXED : joinFlags & ~FLAG_JOIN_START_FIXED);
    inline void fixStartAndEndSpeed()
        joinFlags |= FLAG_JOIN_END_FIXED | FLAG_JOIN_START_FIXED;
    inline bool isEndSpeedFixed()
        return joinFlags & FLAG_JOIN_END_FIXED;
    inline void setEndSpeedFixed(bool newState)
        joinFlags = (newState ? joinFlags | FLAG_JOIN_END_FIXED : joinFlags & ~FLAG_JOIN_END_FIXED);
    inline bool isWarmUp()
        return flags & FLAG_WARMUP;
    inline uint8_t getWaitForXLinesFilled()
        return primaryAxis;
    inline void setWaitForXLinesFilled(uint8_t b)
        primaryAxis = b;
    inline bool isExtruderForwardMove()
        return (dir & E_STEP_DIRPOS)==E_STEP_DIRPOS;
    inline void block()
        flags |= FLAG_BLOCKED;
    inline void unblock()
        flags &= ~FLAG_BLOCKED;
    inline bool isBlocked()
        return flags & FLAG_BLOCKED;
    inline bool isCheckEndstops()
        return flags & FLAG_CHECK_ENDSTOPS;
    inline bool isNominalMove()
        return flags & FLAG_NOMINAL;
    inline void setNominalMove()
        flags |= FLAG_NOMINAL;
    inline void checkEndstops()
        if(isCheckEndstops())
            if(isXNegativeMove() && Printer::isXMinEndstopHit())
                setXMoveFinished();
            if(isYNegativeMove() && Printer::isYMinEndstopHit())
                setYMoveFinished();
            if(isXPositiveMove() && Printer::isXMaxEndstopHit())
                setXMoveFinished();
            if(isYPositiveMove() && Printer::isYMaxEndstopHit())
                setYMoveFinished();
#if FEATURE_Z_PROBE
        if(Printer::isZProbingActive() && isZNegativeMove() && Printer::isZProbeHit())
            setZMoveFinished();
            Printer::stepsRemainingAtZHit = stepsRemaining;
#endif
            // Test Z-Axis every step if necessary, otherwise it could easyly ruin your printer!
            if(isZNegativeMove() && Printer::isZMinEndstopHit())
                setZMoveFinished();
        if(isZPositiveMove() && Printer::isZMaxEndstopHit())
#if MAX_HARDWARE_ENDSTOP_Z
#endif
            setZMoveFinished();
            setZMoveFinished();
#if DRIVE_SYSTEM==CARTESIAN || NONLINEAR_SYSTEM
        dir&=~16;
#else
        dir&=~48;
#endif
        dir&=~32;
#else
        dir&=~48;
#endif
        dir&=~64;
        dir&=~48;
        return (dir & X_STEP_DIRPOS)==X_STEP_DIRPOS;
        return (dir & X_STEP_DIRPOS)==XSTEP;
        return (dir & Y_STEP_DIRPOS)==Y_STEP_DIRPOS;
        return (dir & Y_STEP_DIRPOS)==YSTEP;
        return (dir & Z_STEP_DIRPOS)==Z_STEP_DIRPOS;
        return (dir & Z_STEP_DIRPOS)==ZSTEP;
        return (dir & E_STEP_DIRPOS)==ESTEP;
    inline bool isXOrZMove()
        return dir & (XSTEP | YSTEP);
        dir |= XSTEP<<axis;
    inline static void resetPathPlanner()
        linesCount = 0;
        linesPos = linesWritePos;
        Printer::setMenuMode(MENU_MODE_PRINTING,false);
    // Only called from bresenham -> inside interrupt handle
    inline void updateAdvanceSteps(speed_t v,uint8_t max_loops,bool accelerate)
#if USE_ADVANCE
        if(!Printer::isAdvanceActivated()) return;
        long advanceTarget = Printer::advanceExecuted;
        if(accelerate)
            for(uint8_t loop = 0; loop<max_loops; loop++) advanceTarget += advanceRate;
            if(advanceTarget>advanceFull)
                advanceTarget = advanceFull;
            for(uint8_t loop = 0; loop<max_loops; loop++) advanceTarget -= advanceRate;
            if(advanceTarget<advanceEnd)
                advanceTarget = advanceEnd;
        long h = HAL::mulu16xu16to32(v, advanceL);
        int tred = ((advanceTarget + h) >> 16);
        HAL::forbidInterrupts();
        Printer::extruderStepsNeeded += tred-Printer::advanceStepsSet;
        if(tred > 0 && Printer::advanceStepsSet <= 0)
            Printer::extruderStepsNeeded += Extruder::current->advanceBacklash;
        else if(tred < 0 && Printer::advanceStepsSet >= 0)
            Printer::extruderStepsNeeded -= Extruder::current->advanceBacklash;
        Printer::advanceStepsSet = tred;
        HAL::allowInterrupts();
        Printer::advanceExecuted = advanceTarget;
#else
        int tred = HAL::mulu6xu16shift16(v, advanceL);
        Printer::extruderStepsNeeded += tred - Printer::advanceStepsSet;
            Printer::extruderStepsNeeded += (Extruder::current->advanceBacklash << 1);
            Printer::extruderStepsNeeded -= (Extruder::current->advanceBacklash << 1);
#endif
#endif
    inline bool moveDecelerating()
        if(stepsRemaining <= decelSteps)
            if (!(flags & FLAG_DECELERATING))
                Printer::timer = 0;
                flags |= FLAG_DECELERATING;
            return true;
        else return false;
    inline bool moveAccelerating()
        return Printer::stepNumber <= accelSteps;
    inline bool isFullstepping()
        return halfStep == 4;
    inline void startXStep()
#if !(GANTRY)
        WRITE(X_STEP_PIN,HIGH);
#if FEATURE_TWO_XSTEPPER
        WRITE(X2_STEP_PIN,HIGH);
#endif
#else
#if DRIVE_SYSTEM == XY_GANTRY || DRIVE_SYSTEM == XZ_GANTRY
        if(isXPositiveMove())
            Printer::motorX++;
            Printer::motorYorZ++;
            Printer::motorX--;
            Printer::motorYorZ--;
#endif
#if DRIVE_SYSTEM == YX_GANTRY || DRIVE_SYSTEM == ZX_GANTRY
            Printer::motorX++;
            Printer::motorX--;
#endif
#endif
        totalStepsRemaining--;
#endif
    inline void startYStep()
#if !(GANTRY) || DRIVE_SYSTEM == ZX_GANTRY || DRIVE_SYSTEM == XZ_GANTRY
        WRITE(Y_STEP_PIN,HIGH);
#if FEATURE_TWO_YSTEPPER
        WRITE(Y2_STEP_PIN,HIGH);
#endif
#else
#if DRIVE_SYSTEM==XY_GANTRY
        if(isYPositiveMove())
            Printer::motorX++;
            Printer::motorX--;
#endif
#if DRIVE_SYSTEM==YX_GANTRY
            Printer::motorX++;
            Printer::motorX--;
#endif
#endif // GANTRY
#endif
    inline void startZStep()
#if !(GANTRY) || DRIVE_SYSTEM == YX_GANTRY || DRIVE_SYSTEM == XY_GANTRY
        WRITE(Z_STEP_PIN,HIGH);
#if FEATURE_TWO_ZSTEPPER
        WRITE(Z2_STEP_PIN,HIGH);
#endif
#else
#if DRIVE_SYSTEM==XZ_GANTRY
            Printer::motorX++;
            Printer::motorX--;
#endif
#if DRIVE_SYSTEM==ZX_GANTRY
            Printer::motorX++;
            Printer::motorX--;
#endif
#endif
    void updateStepsParameter();
    inline float safeSpeed();
    void calculateMove(float axis_diff[],uint8_t pathOptimize);
    void logLine();
    inline long getWaitTicks()
        return timeInTicks;
    inline void setWaitTicks(long wait)
        timeInTicks = wait;
    static inline bool hasLines()
        return linesCount;
    static inline void setCurrentLine()
        cur = &lines[linesPos];
        PrintLine::nlFlag = true;
#endif
    // Only called from within interrupts
    static inline void removeCurrentLineForbidInterrupt()
        linesPos++;
        if(linesPos >= PRINTLINE_CACHE_SIZE) linesPos=0;
        cur = NULL;
        nlFlag = false;
#endif
        --linesCount;
        if(!linesCount)
    static inline void pushLine()
        linesWritePos++;
        if(linesWritePos >= PRINTLINE_CACHE_SIZE) linesWritePos = 0;
        Printer::setMenuMode(MENU_MODE_PRINTING,true);
        InterruptProtectedBlock noInts;
        linesCount++;
    static uint8_t getLinesCount() {
        return linesCount;
    static PrintLine *getNextWriteLine()
        return &lines[linesWritePos];
    static inline void computeMaxJunctionSpeed(PrintLine *previous,PrintLine *current);
    static int32_t bresenhamStep();
    static void waitForXFreeLines(uint8_t b=1, bool allowMoves = false);
    static inline void forwardPlanner(uint8_t p);
    static inline void backwardPlanner(uint8_t p,uint8_t last);
    static void updateTrapezoids();
    static uint8_t insertWaitMovesIfNeeded(uint8_t pathOptimize, uint8_t waitExtraLines);
    static void queueCartesianMove(uint8_t check_endstops,uint8_t pathOptimize);
    static void moveRelativeDistanceInSteps(int32_t x,int32_t y,int32_t z,int32_t e,float feedrate,bool waitEnd,bool check_endstop);
    static void moveRelativeDistanceInStepsReal(int32_t x,int32_t y,int32_t z,int32_t e,float feedrate,bool waitEnd);
#if ARC_SUPPORT
    static void arc(float *position, float *target, float *offset, float radius, uint8_t isclockwise);
#endif
    static inline void previousPlannerIndex(uint8_t &p)
        p = (p ? p-1 : PRINTLINE_CACHE_SIZE-1);
    static inline void nextPlannerIndex(uint8_t& p)
        p = (p == PRINTLINE_CACHE_SIZE - 1 ? 0 : p + 1);
    static uint8_t queueDeltaMove(uint8_t check_endstops,uint8_t pathOptimize, uint8_t softEndstop);
    static inline void queueEMove(long e_diff,uint8_t check_endstops,uint8_t pathOptimize);
    inline uint16_t calculateDeltaSubSegments(uint8_t softEndstop);
    static inline void calculateDirectionAndDelta(long difference[], flag8_t *dir, long delta[]);
    static inline uint8_t calculateDistance(float axis_diff[], uint8_t dir, float *distance);
#if SOFTWARE_LEVELING && DRIVE_SYSTEM == DELTA
    static void calculatePlane(long factors[], long p1[], long p2[], long p3[]);
    static float calcZOffset(long factors[], long pointX, long pointY);
#endif
#endif
#endif // MOTION_H_INCLUDED
[EDIT] code Tags sind in der neuen SW des Forum anders codiert. am sichersten man nimmt </> im Editorfenster. Korrigiert. Grüße Uwe [/EDIT]
Du könntest versuchen, das vorige nochmal zu editieren und dabei
  • die Code - Tags richtig zu setzen, damit er lesbar wird
  • die Fehlermeldung zeigen
  • den Code so einrücken, dass er besser lesbar ist. (Strg-T in der Arduino IDE)
    [Edit:] Danke, Uwe [/Edit]
macht dir das dopelte
#include <EEPROM.h>
Probleme?
Uwe, normalerweise stört eine doppelte Library Angabe nicht und produziert auch keine Fehlermeldung.
Hallo,
ich hab mal versucht das zu kompilieren. Vermute es fehlt eine Lib. es gibt einige Fehler u.A
lies dir noch mal die readme auf Github durch
exit status 1
'flag8_t' does not name a type
Heinz
