Hallo Leute,
Nutze ein Arduino Mega 2560 und ein 1,8" LCD von SainSmart.
Folgender Code wird genutzt, läuft aber nicht:
// Pins SCLK and MOSI are fixed in hardware, and pin 10 (or 53)
// must be an output
//#define sclk 13 // for MEGAs use pin 52
//#define mosi 11 // for MEGAs use pin 51
#define cs 10 // for MEGAs you probably want this to be pin 53
#define dc 9
#define rst 8 // you can also connect this to the Arduino reset
// Color definitions
#define BLACK 0x0000
#define BLUE 0x001F
#define RED 0xF800
#define GREEN 0x07E0
#define CYAN 0x07FF
#define MAGENTA 0xF81F
#define YELLOW 0xFFE0
#define WHITE 0xFFFF
#include <ST7735.h>
#include <SPI.h>
// Option 1: use any pins but a little slower
//ST7735 tft = ST7735(cs, dc, mosi, sclk, rst);
// Option 2: must use the hardware SPI pins
// (for UNO thats sclk = 13 and sid = 11) and pin 10 must be
// an output. This is much faster - also required if you want
// to use the microSD card (see the image drawing example)
ST7735 tft = ST7735(cs, dc, rst);
void fillpixelbypixel(uint16_t color) {
for (uint8_t x=0; x < tft.width; x++) {
for (uint8_t y=0; y < tft.height; y++) {
tft.drawPixel(x, y, color);
delay(100);
void setup(void) {
Serial.print("hello!");
tft.initR(); // initialize a ST7735R chip
Serial.println("init");
tft.writecommand(ST7735_DISPON);
uint16_t time = millis();
tft.fillScreen(BLACK);
time = millis() - time;
Serial.println(time, DEC);
testdrawtext("Lorem ipsum dolor sit amet, consectetur adipiscing elit. Curabitur adipiscing ante sed nibh tincidunt feugiat. Maecenas enim massa, fringilla sed malesuada et, malesuada sit amet turpis. Sed porttitor neque ut ante pretium vitae malesuada nunc bibendum. Nullam aliquet ultrices massa eu hendrerit. Ut sed nisi lorem. In vestibulum purus a tortor imperdiet posuere. ", WHITE);
delay(10000);
//a single pixel
tft.drawPixel(tft.width/2, tft.height/2, GREEN);
// line draw test
testlines(YELLOW);
// optimized lines
testfastlines(RED, BLUE);
testdrawrects(GREEN);
testfillrects(YELLOW, MAGENTA);
testfillcircles(10, BLUE);
testdrawcircles(10, WHITE);
Serial.println("done");
tft.writecommand(ST7735_INVON);
tft.writecommand(ST7735_INVOFF);
void testlines(uint16_t color) {
for (uint16_t x=0; x < tft.width; x+=6) {
tft.drawLine(0, 0, x, tft.height-1, color);
for (uint16_t y=0; y < tft.height; y+=6) {
tft.drawLine(0, 0, tft.width-1, y, color);
tft.drawLine(tft.width-1, 0, x, tft.height-1, color);
tft.drawLine(tft.width-1, 0, 0, y, color);
tft.drawLine(0, tft.height-1, x, 0, color);
tft.drawLine(0, tft.height-1, tft.width-1, y, color);
tft.drawLine(tft.width-1, tft.height-1, x, 0, color);
tft.drawLine(tft.width-1, tft.height-1, 0, y, color);
void testdrawtext(char *text, uint16_t color) {
tft.drawString(0, 0, text, color);
void testfastlines(uint16_t color1, uint16_t color2) {
for (uint16_t y=0; y < tft.height; y+=5) {
tft.drawHorizontalLine(0, y, tft.width, color1);
for (uint16_t x=0; x < tft.width; x+=5) {
tft.drawVerticalLine(x, 0, tft.height, color2);
void testdrawrects(uint16_t color) {
tft.drawRect(tft.width/2 -x/2, tft.height/2 -x/2 , x, x, color);
void testfillrects(uint16_t color1, uint16_t color2) {
for (uint16_t x=tft.width-1; x > 6; x-=6) {
tft.fillRect(tft.width/2 -x/2, tft.height/2 -x/2 , x, x, color1);
tft.drawRect(tft.width/2 -x/2, tft.height/2 -x/2 , x, x, color2);
void testfillcircles(uint8_t radius, uint16_t color) {
for (uint8_t x=radius; x < tft.width; x+=radius*2) {
for (uint8_t y=radius; y < tft.height; y+=radius*2) {
tft.fillCircle(x, y, radius, color);
void testdrawcircles(uint8_t radius, uint16_t color) {
for (uint8_t x=0; x < tft.width+radius; x+=radius*2) {
for (uint8_t y=0; y < tft.height+radius; y+=radius*2) {
tft.drawCircle(x, y, radius, color);
Ist ein Example vom Hersteller... Alles nach angaben aufgelegt.
