KSduino
Has anyone ever used KSduino?
I am trying to get this up and running. I have linked the code below, but cannot get it working
I was trying to even get my w5200 up and running today and spent all day figuring out that the w5200 was not compatible with the w5100 code. Thanks for SurferTim, I was able to download another code and get my WebServer test code working properly.
If anyone could help with KSduino, i would really appreciate it.
Thanks!
John
/* -- Mode: C; indent-tabs-mode: t; c-basic-offset: 2; tab-width: 2 -- /
  • KSduino Simple-01 Example Sketch
  • simple_01.ino
  • KSduino Simple-01 is KSduino-library example sketch
  • This example is a part of KSduino Libray for Arduino
  • Copyright (C) Kirill Scherba 2012 kirill@scherba.ru
  • KSduino library & examples is free software: you can redistribute it and/or modify it
  • under the terms of the GNU General Public License as published by the
  • Free Software Foundation, either version 3 of the License, or
  • (at your option) any later version.
  • ksduino-server is distributed in the hope that it will be useful, but
  • WITHOUT ANY WARRANTY; without even the implied warranty of
  • MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
  • See the GNU General Public License for more details.
  • You should have received a copy of the GNU General Public License along
  • with this program. If not, see http://www.gnu.org/licenses/.
  • @file simple_01.ino
  • Simple-01 is an Example for Getting Started with KSduino Library
// Includes -------------------------------------------------------------
#include <SPI.h>
#include <EthernetUdp.h>
#include <KSduino.h>
// User definition -----------------------------------------------------
// Change this values to yours
// Your Arduinos ID & Password
unsigned int deviceID = 3436;
unsigned int devicePwd = 1025;
// Your Arduinos MAC, IP & port used in your local network
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 10, 0, 0, 38 };
unsigned int port = 58833;
// Server definition -----------------------------------------------------
// Do not change this values
// KSduino Server address & port
byte serverIp[] = { 178,63,53,233 };
unsigned int serverPort = 9930;
// Create KSduino class
KSduino ksd (deviceID, devicePwd, serverIp, serverPort);
// Start KSduino at the beginning of setup
ksd.begin (mac, ip, port);
static byte d_value = LOW;
// Set value to D1 variable
if (d_value == LOW) d_value = HIGH; else d_value = LOW;
// Send D1 value to KSduino server
ksd.sendOne ("d1", d_value);
// Do delay
delay (1000);
// KSduino update should be at the end of loop
ksd.update ();
