kty 10 linearisation
hy everyone!
I am trying to make a temperature sensor and linearise it,...
I hope You uderstand what I mean... I am not yet familiar with the whole terminologie :frowning: but I am working on it :slight_smile:
I want to make a temperature sensor with kty 10 and arduino, wich will give me a reading in celsius on a 8x2 LCD display.
I want to do it, but I cant get the math.h library to work...
it wont turn red when I try to include it, and I have no way of knowing if I put in the equation coretly... using sqr, and rt functions is crutial if I want a linear masuremant, right?
THIS IS WHAT I HAVE SO FAR, BUT IT IS NOWHERE NEAR CLOSE TO MY GOAL...
#include <LiquidCrystal.h>
double vrednost = 0;
int backLight = 13; //pin 13 nadzor osvetlitve zaslona (control of display backlight)
LiquidCrystal lcd(10,11,12,13,14,15,16);
int analogPin=4;
int analogValue = 0;
float napetost = 0; //napetost = voltage
pinMode(backLight, OUTPUT);
digitalWrite(backLight,HIGH);
lcd.begin(2,16);
lcd.clear();
analogValue = analogRead(analogPin);
napetost = analogValue * 1023 / 8 / 150; //napetost = VOLTAGE, and I need to put in the equation wich linearises the reading, but am not shure how to do it
Serial.print(napetost); //napetost = voltage
Serial.println("C");
lcd.clear();
lcd.setCursor(1,0);
lcd.print(napetost);
lcd.setCursor(1,1);
lcd.print("stopinj C"); //STOPINJ = DEGREES CELSIUS
delay(100);
any help from you good people would much apriciated :slight_smile:
vito (thats my name :))
There needs to be a keywords.txt file accompanying any Arduino specific library, with the appropriate entry to make the include line turn red. The math.h file is not Arduino-specific, so it will not turn red.
You know that you put the equation in in a way that is syntactically correct if the program compiles. You know that you put the equation in in a way that is logically correct if the program then produces valid results,
first of, thank you!
so if I understand this right, math.h will not turn red even if I put it in corectly?
can you show me what you mean with keywords.txt, pleese.
and how do you think I should put and wich formula in the equation?
THANK YOU
Correct.
http://arduino.cc/en/Hacking/LibraryTutorial would be a good place to start if you are developing a library. If you are just using a library, you don't need to know how other people develop keywords.txt files.
Every library comes with a keywords.txt file. Feel free to browse some of them.
Start with the data sheet for your sensor...
THANK YOU!!!
Ill get right on it, and Ill let you know what is the result.
