Hey folks, I'm trying to use a KY-024 hall effect sensor, to accurately measure the RPM's of a flywheel project I'm working on.
I found some code, but it doesn't seem to be too reliable. I tried testing with a drill at a constant speed, and the readings were all over the place.
I tried messing with the sample time, but no luck.
I thought maybe adding two magnets, on opposite ends, but I'm not sure how to adjust the code.
Was hoping for a hand over this little roadblock.
Thanks in advance for any assistance!
RPM meter code (tested on device rotating at 10,000 rpm)
rev.001
* using a hall effect sensor
http://www.adafruit.com/index.php?main_page=product_info&cPath=35&products_id=158
* using a parallel LCD with
LiquidCrystal Library
http://www.ladyada.net/learn/lcd/charlcd.html
http://www.arduino.cc/en/Tutorial/LiquidCrystal
with pins 7,6,5,4,3,2
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7,6,5,4,3,2);
// read the hall effect sensor on pin 2
const int hallPin=8;
const unsigned long sampleTime=1000;
const int maxRPM = 10200;
pinMode(hallPin,INPUT);
// set up the LCD's number of rows and columns:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("initializing");
lcd.clear();
delay(10);
int rpm=getRPM();
lcd.clear();
displayRPM(rpm);
displayBar(rpm);
int getRPM()
// sample for sampleTime in millisecs
int kount=0;
boolean kflag=LOW;
unsigned long currentTime=0;
unsigned long startTime=millis();
while (currentTime<=sampleTime)
if (digitalRead(hallPin)==HIGH)
kflag=HIGH;
if (digitalRead(hallPin)==LOW && kflag==HIGH)
kount++;
kflag=LOW;
currentTime=millis()-startTime;
int kount2rpm = int(60000./float(sampleTime))*kount;
return kount2rpm;
void displayRPM(int rpm)
lcd.clear();
// set the cursor to column 0, line 1
lcd.setCursor(0, 0);
// print the number of seconds since reset:
lcd.print(rpm,DEC);
lcd.setCursor(7,0);
lcd.print("RPM");
void displayBar(int rpm)
int numOfBars=map(rpm,0,maxRPM,0,15);
lcd.setCursor(0,1);
if (rpm!=0)
for (int i=0; i<=numOfBars; i++)
lcd.setCursor(i,1);
lcd.write(1023);
