KY-039 PulseRate Sensor + Servo Motor
I’m an Art & Design student and just started to learn how to use Arduino in a current project.
I have a basic understanding in coding and would hope that someone can help me out in this project.
So this project is INPUT and OUTPUT. And my input would be Pulse Rate Sensor and OUTPUT would be servo motor. The whole idea is to make the Servo motor move 180degrees then back once with a 5-10sec delay in between, when the Pulse Rate sensor receives a data up to 150 or above.
The following is my code. I’m sorry if i don’t know much and just trying to combine two sketches together but please help :frowning:
const int ledPin = 13;
const int sensePin = A0;
// LED blink variables
int ledState = LOW;
long ledOnMillis = 0;
long ledOnInterval = 50;
// Hearbeat detect variables
int newHeartReading = 0;
int lastHeartReading = 0;
int Delta = 0;
int recentReadings[8] = {0,0,0,0,0,0,0,0};
int historySize = 8;
int recentTotal = 0;
int readingsIndex = 0;
boolean highChange = false;
int totalThreshold = 2;
// Heartbeat Timing
long lastHeartbeatTime = 0;
long debounceDelay = 150;
int currentHeartrate = 0;
#include <Servo.h>
Servo myservo;
int pos = 0;
myservo.attach(9);
// initialize the digital pin as an output:
pinMode(ledPin, OUTPUT);
// Turn off LED
digitalWrite(ledPin, LOW);
// Read analogue pin.
newHeartReading = analogRead(sensePin);
//Serial.println(newHeartReading);
//Calculate Delta
Delta = newHeartReading - lastHeartReading;
lastHeartReading = newHeartReading;
// Find new recent total
recentTotal = recentTotal - recentReadings[readingsIndex] + Delta;
// replace indexed recent value
recentReadings[readingsIndex] = Delta;
// increment index
readingsIndex = (readingsIndex + 1) % historySize;
//Debug
//Serial.println(recentTotal);
// Decide whether to start an LED Blink.
if (recentTotal >= totalThreshold) {
// Possible heartbeart, check time
if (millis() - lastHeartbeatTime >= debounceDelay) {
// Heartbeat
digitalWrite(ledPin, HIGH);
currentHeartrate = 60000 / (millis() - lastHeartbeatTime);
lastHeartbeatTime = millis();
// Print Results
//Serial.println(“Beat”);
if (currentHeartrate <= 200)
{ Serial.println(currentHeartrate); } } } delay(10);
if (analogRead () <= 150)
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable ‘pos’
delay(15); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
