Hello. L diode on Arduino PCB lights all the time. When I upload this program:
L diode is lighting. When I put LED diode in pin 13 and GND L diode turning off. It is normal? Moreover my Arduino was detected in computer as "Unknown device".
Could anyone help me and check this code on Arduino UNO R3?
Thanks for reply.
Yes, I installed drivers for Arduino.
When I drive LED in pin13 and GND (without resistor), L diode lights less. But when I connect it with 220? resistor, there ale no changes. Moreover, L brightness (without program) changes when I touch the pins 13 and GND with finger.
I bought Arduino few days ago, should I send it back?
So yo say that every Arduino UNO behaves in the same way. Because if this is a normal operation, then our Arduino's are fine and all the others are faulty...
I think the bootloader blinks the LED. When it finishes it sets it to input, but may be still HIGH. The SMD LED is powerful enough to glow. It probably shouldn't do that, but you can always set pin 13 to LOW as the first line of your program it it troubles you.
We've established that the R3 Unos have an op-amp that drives the LED, and if the pin is floating the op-amp will probably turn the LED on. Your solution of a small resistance effectively brings that pin (13) low with a weak pull-down, and then the op-amp doesn't drive the LED.
