L293d Dual Motor Control
Qns: I am doing a project ( Line follower-robot) , What do I need to change in order to make the two motors turn in same direction at the same time?
Test code with Arduino
As a simple test, you can make the motors turn forward and backward alternatively with this code:
// initialize the digital pins as outputs.
// Pin 13 has a LED connected on most Arduino boards:
pinMode(13, OUTPUT);
pinMode(7, OUTPUT);//Motor connected on pin 7 en 8, these are PWM capable
pinMode(8, OUTPUT);
digitalWrite(7, HIGH); //start motor at full speed
digitalWrite(8, LOW);
digitalWrite(13, HIGH); //turn on LED
delay(5000);//wait
digitalWrite(7, LOW); //stop motor
delay(1000); //wait a second to be sure motor is stopped
digitalWrite(7, LOW); //start motor in reverse direction, full speed
digitalWrite(8, HIGH);
digitalWrite(13, LOW); //turn off led
delay(5000);//wacht
Speed control
Just like with the LED in the first session, the analogWrite() command can be used to set a speed for the
motor:
// Pin 13 has an LED connected on most Arduino boards:
pinMode(5, OUTPUT);//Motor aangesloten op pin 7 en 8, deze zijn PWM capable
pinMode(6, OUTPUT);
digitalWrite(6, LOW);
analogWrite(5, 128);
digitalWrite(13, LOW);//Show speed on LED
delay(4000); //wait a bit
analogWrite(5, 255);
digitalWrite(13, HIGH);//Show speed on LED
delay(4000);
  1. You need to post your code between [ code] [ /code] tags. Use the # button above the smileys.
  2. You can only have one setup() and one loop() in any program.
  3. You need to get rid of your delay()s. See the 'blink without delay' example in the IDE (File > Examples > 02.digital > blinkwithoutdelay). Your Arduino can't do anything else when it's in a delay.
  4. Look up 'Finite State Machine' for how to order your code, so that it follows a logical, easy to understand, sequence.
For simple testing, but probably not for real life with all those delays as already pointed out, you can simply duplicate the code for another motor. Probably best to use variable names for the pins, easier to keep track of.
Btw on a Uno pins 7 and 8 are not PWM as your comment says: but then you didn't say what board you have.
Anyway, where you have this:
 pinMode(6, OUTPUT);
.... you could add another motor on say pins 10 and 11:
 pinMode(6, OUTPUT);
 pinMode(10, OUTPUT);//Motor aangesloten op pin 7 en 8, deze zijn PWM capable
 pinMode(11, OUTPUT);
Connect pins 10 and 11 to the unused input pins on the L293 (we don't know which ones you used: you should post a schematic), and the second motor on the unused output pins (we don't know which ones you used: you should post a schematic).
Then lines like this for an existing motor:
.... become like this for the new one:
analogWrite(10, 128);
http://people.mech.kuleuven.be/~dvanthienen/soiree_pratique/HackerManual.pdf
Here' the link for the circuit diagram. Please take a look.
Chinhao:
I'm just leaving home for work.... will try to get a gap later.
Chinhao:
Apply your mind; have a look at the photo in that pdf.... One motor has pink wires from Arduino, one has blue. So trace back to the pin numbers on Arduino, and adjust / add code as appropriate. Hint: kind of double-up the code but on a new set of pins.
