hi, well when i connect directly i get so damn good performance my blade just flys itself even tought its glued !! but whit l293 driven from arduino i get low speed !
a mosfet didnt reduce speed !
i used my multimeter to check things i got 7.75v from 7.95v which on the datasheet its normal:((
but the current
falled from 250ma(direct) to 170 (using L293D) anyway to reduce this ??? i connected my 8v batterys (6 1.2 v)
to l293d left lower corner and the - to power rail connected both sides and arduinos ground to breadboard ground and + to breadboards + i will upload fritzing image if you want !!!
That's the problem with BJT transistor, they can drop a lot of voltage.
Leaves less voltage across the load.
(Vsource - Vtransistor)/Rload = current.
Want higher current? Need lower Vtransistor >> MOSFET
i tried digitalWrite(5,HIGH); too gave me exact same results.
mosfet takes a lot of space im already out of space im ordering new chassis but on my current one ( 4 wheels 2 motors one im ordering got 2 wheels) dont have any place for battery ! mine is huge ( lego triangle 6AA batteries holder)
See page 5 - Voh: VCC - 1.8 to VCC -1.4.
So 1.4 to 1.8V of voltage drop across the output.
And that's at just 0.6A - it increase as current goes up to 1.2A max limit.
CrossRoads: http://www.ti.com/lit/ds/symlink/l293d.pdf
that is so bad:((
seeing if L298 got same amout of voltage drop !!!! but i dont really need speed for my robot but still thats so sad ! wasting battery!
