Hello I have an RC car which has two 3v motors (one for left/right and the other one for forward/back). The left and right motor is working fine but when I try to rotate the other motor it rotates only back. I’ve tried the motor separately and it works in both direction without the controller.
I’ve also attached the wiring. The green and orange wires are just for a bluetooth module.
My code is the following:
int enablePinMotorAF = 3;
int in1PinMotorAF = 5;
int in2PinMotorAF = 6;
int enablePinMotorLR = 11;
int in1PinMotorLR = 10;
int in2PinMotorLR = 9;
boolean reverse = true;
pinMode(enablePinMotorAF, OUTPUT);
pinMode(in1PinMotorAF, OUTPUT);
pinMode(in2PinMotorAF, OUTPUT);
pinMode(enablePinMotorLR, OUTPUT);
pinMode(in1PinMotorLR, OUTPUT);
pinMode(in2PinMotorLR, OUTPUT);
//go forward ->not working
analogWrite(enablePinMotorAF, 230);
digitalWrite(in1PinMotorAF, reverse);
digitalWrite(in2PinMotorAF, !reverse);
delay(3000);
//go back -> working
digitalWrite(in1PinMotorAF, !reverse);
digitalWrite(in2PinMotorAF, reverse);
delay(3000);
//go right -> working
analogWrite(enablePinMotorLR, 230);
digitalWrite(in1PinMotorLR, !reverse);
digitalWrite(in2PinMotorLR, reverse);
delay(3000);
//go left -> working
digitalWrite(in1PinMotorLR, reverse);
digitalWrite(in2PinMotorLR, !reverse);
delay(3000);
Do you have any idea how can I solve this problem and to make it work?
Thank you.
