Hey everyone I just wanna check my connections please help me with this i was doing a project there I was try l293d motor driver ckt in that I used 1 uF capacitor one terminal is connected to vcc1 and other is gnd and lm7805 connect its input with vcc2 and output with vcc1 of l293d and I am using lm7805 as voltage regulator for 5v ouput voltage
So far what you've described might work, but the problem is that your description still leaves plenty of opportunities for misunderstanding/miscommunication. A schematic solves this.
Also specify whether you're using a bare L293D chip or a module that uses this chip; post a photo if you can.
Also please specify what the L293D will drive; what kind of motor etc.; post/link to a datasheet please.
I USED L293D for motors only but I just want to confirm that if I used lm7805 and its input pin connected to Vcc2 and the output pin connected to Vcc1 then when I give more than 5v to the motors imput would the lm7805 in the circuit reduced it and make it 5v also I connected my 1uf capacitor to vcc1 where I give 5v to initiate the logic for IC
