Hi , I'm looking for clarification to use of the L298 in LAP.
i've done this circuit with eagle , pwm is on the IN1 and IN2 , and i have connected a digital output on the ENABLE ;
so could you tell me if the schematic is correct ? , and how can i programm the pwm with this configuration ? because when the pwm is 50% the motors should stop;
From his ckt and description, LAP apparently means Locked Anti-Phase. Some people
use this, I never have. The motors grind too much, full power all the time, lot of heat.
The schematic appears to be ok, but I don't understand "how can i programm the pwm
with this configuration", as it should be apparent.
i mean ,how can i write the code for this configuration ? because i have no idea , i might use AnalogWrite (PIN , 255);
but i'm not sure.
Please help me and thank you
Just go on and try it, and see how it works. That's the "proof of the pudding", as they say.
As I mentioned, I haven't done it myself, and I never decide on anything until I've actually
tried it myself.
