Kindly check out this video: HOW TO: control DC Motors with Arduino + L298N - YouTube
This video using following connections:
L298N 12V pin to +ve battery panel
L298N GND pin to -ve battery panel
L298N two middle pin to Digital arduino pins for rotating the motor clockwise or anti-clockwise
L298N one pin to PWM pin of arduino to control the speed of Arduino.
Arduino powered with USB
Now I want to power the Arduino with my 12V battery, so can I do connections like this below?
L298N 12V pin to 12V +ve battery panel
L298N GND pin to 12V -ve battery panel
Arduino powered with same battery panel as above using DC socket (basically common'ing the battery for motors + arduino power)
OR do you suggest any alternate approach? IF yes, which one? Please help!
Take a look at this: Overview | Arduino Lesson 15. DC Motor Reversing | Adafruit Learning System
What you could do is power the Arduino separately, connect the +V pin on the h bridge to arduino's 5V, and then the battery to the +Vmotor pin on the h bridge, and then make sure you connect the grounds all around. Everything else sounds about right.
Hello chummer1010, I didn't understand it properly. Also I want to power Arduino using DC socket.
zoma786:
I thought you wanted to use a '12v battery'?
Not fritzy diagram.
Can you please post a copy of your sketch, using code tags?
They are made with the </> icon in the reply Menu.
See section 7 http://forum.arduino.cc/index.php/topic,148850.0.html
Thanks… Tom…
What chummer1010 means :
Is that L293D is a H-Bridge chip as well which can drive up to 2 motors, you need to power up the
chip providing +5V to VCC and the 2 Enables which are in the Top left corner and bottom right corner,
powering your motors you will need to add a battery up to 12V or lower to the VCC2 which is the bottom
left corner and GND:
Bellow you can view the URL’s and chose the tutorial you like to follow and build your project:
- http://letsmakerobots.com/node/32041
http://hardwarefun.com/tutorials/controlling-speed-of-dc-motors-using-arduino
(here you will find code as well) just plug, upload and play.
About the price of a L293D chip comes up at 0.50$ cents so as you see it’s really cheap
and nice to use on projects, btw as well you will need a heat sink because they going to
get hot.
D.60
