L298n Motor Driver Code
I have code to use an L298N motor driver. I have 1 DC motor connected and am only interested in moving it in the forwards direction. How would I be able to slim down this code, so that it is only activated for the desired amount of time, when called upon?
Thanks
// Motor A
int motor1Pin1 = 27;
int motor1Pin2 = 26;
int enable1Pin = 14;
// Setting PWM properties
const int freq = 30000;
const int pwmChannel = 0;
const int resolution = 8;
int dutyCycle = 200;
  // sets the pins as outputs:
  pinMode(motor1Pin1, OUTPUT);
  pinMode(motor1Pin2, OUTPUT);
  pinMode(enable1Pin, OUTPUT);
  // configure LED PWM functionalitites
  ledcSetup(pwmChannel, freq, resolution);
  // attach the channel to the GPIO to be controlled
  ledcAttachPin(enable1Pin, pwmChannel);
  // testing
  Serial.print("Testing DC Motor...");
  // Move the DC motor forward at maximum speed
  Serial.println("Moving Forward");
  digitalWrite(motor1Pin1, LOW);
  digitalWrite(motor1Pin2, HIGH);
  delay(2000);
  // Move DC motor forward with increasing speed
  digitalWrite(motor1Pin1, HIGH);
  digitalWrite(motor1Pin2, LOW);
  while (dutyCycle <= 255){
    ledcWrite(pwmChannel, dutyCycle);
    Serial.print("Forward with duty cycle: ");
    Serial.println(dutyCycle);
    dutyCycle = dutyCycle + 5;
  dutyCycle = 200;
use one of the PWM pins
use analogWrite() to set the pin to a non-zero value to enable the motor
recognize a button or when to enable the motor and capture a timestamp.
in loop() check if the time since the timestamp has expired and disable the motor
Non-blocking timing tutorials:
Blink without delay().
Beginner's guide to millis().
Several things at a time.
// example.
// Motor A
#define motor1Pin1  7  //<<<<<<<<<<<<<<<<<<<<<
#define motor1Pin2  6  //<<<<<<<<<<<<<<<<<<<<<
#define enable1Pin  14
const byte dutyCycle = 200;
  digitalWrite(enable1Pin, LOW); /// active HIGH ?
  if (something == happening)Forward(2000);
void Forward(unsigned long howLong) {
  unsigned long startTime = millis();
  digitalWrite(enable1Pin, HIGH);/// active HIGH ?
  for (byte f = dutyCycle; f > 5; f -= 5) {
    Serial.println(f);
    analogWrite(motor1Pin1, f);
    delay(100);
  while (millis() - startTime < howLong)delay(10);
Okay. Thanks for the replies. I have tried a couple of things, but feel like I may be overcomplicating things for myself. How would I be able to move the motor in the forward direction for 20 seconds?
if (..........) Forward(20000);
