How can i connect a L928N motor driver to a sensor shield 5.0V
L298N Motor Driver Module Pinout, Datasheet, Features & Specs (motor driver)
Sensor Shield V5.0 - ProtoSupplies (sensor shield)
Thanks for providing the links to the products in your first post It earned you a karma
Your sensor shield has two rows of pins that match the Uno form factor.
You can connect your motor driver as you would without the sensor shield. For the digital pins, you use the row that has the S at the left of it. You will need female-to-female dupont cables.
i did that but when i upload the code it is not working (in the code i put the right pins) and one motor is simply running non stop. i put a photo with the sensor shield
Show us a picture with just the motor shield and motor, power supply connections.
Thanks.. Tom..
