Hello,
I have a problem with my L298n Motor Driver and my 12V Stepper Motor.
When I upload my Program on the Arduino the Stepper Motor works one Time how it should be and after that the Motor Activates himself every 2 seconds and moves a little bit.
What is the Problem?
My Code:
#include <Stepper.h>
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 20, 4);
int Button_Rechts = 2;
int Button_Links = 4;
int Button_Auswahl = 3;
int menu = 1;
int tasterstatus1;
int tasterstatus2;
int tasterstatus3;
const int stepsPerRevolution = 1000;
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
lcd.init();
lcd.backlight();
pinMode(Button_Rechts, INPUT);
pinMode(Button_Links, INPUT);
pinMode(Button_Auswahl, INPUT);
updateMenu();
myStepper.setSpeed(40);
tasterstatus1=digitalRead(Button_Rechts);
tasterstatus2=digitalRead(Button_Links);
tasterstatus3=digitalRead(Button_Auswahl);
if (tasterstatus1 == LOW)
menu++;
updateMenu();
delay(200);
// while (!digitalRead(Button_Rechts));
if (tasterstatus2 == LOW)
menu--;
updateMenu();
delay(200);
//while(!digitalRead(Button_Auswahl));
if (tasterstatus3 == LOW)
executeAction();
updateMenu();
void updateMenu() {
switch(menu) {
case 0:
menu = 1;
case 1:
lcd.clear();
lcd.print(" Getraenke Auswahl!");
lcd.setCursor(0, 2);
lcd.print(" Cola Korn");
lcd.setCursor(0, 3);
lcd.print("<--- --->");
case 2:
lcd.clear();
lcd.print(" Sprite Korn");
case 3:
lcd.clear();
lcd.print(" Spezi Korn");
case 4:
lcd.clear();
lcd.print(" Captain Cola");
case 5:
menu = 4;
void executeAction() {
switch (menu) {
case 1:
action1();
case 2:
action2();
case 3:
action3();
case 4:
action4();
void action1() {
lcd.clear();
lcd.setCursor(0, 1);
lcd.print(" Cola Korn wird gemacht: ");
Serial.println("clockwise");
myStepper.step(stepsPerRevolution);
delay(2000);
void action2() {
lcd.clear();
lcd.print(" Sprite Korn wird gemacht: ");
myStepper.step(-stepsPerRevolution);
void action3() {
lcd.clear();
lcd.print(" Spezi Korn wird gemacht: ");
// step one revolution in the other direction:
Serial.println("counterclockwise");
void action4() {
lcd.clear();
lcd.print(" Captain wird gemacht: ");
delay(5000);
