L3G4200D problem
Hello, i used this code, to get values of x y z, the probleme when i move the gyro a lot and i put it on the ground, i have not 0 value from all axes, i have wrong values. what is the problem please
//Arduino 1.0+ only
#include <Wire.h>
#define CTRL_REG1 0x20
#define CTRL_REG2 0x21
#define CTRL_REG3 0x22
#define CTRL_REG4 0x23
#define CTRL_REG5 0x24
int L3G4200D_Address = 105; //I2C address of the L3G4200D
int x = 0;
float p_z = 0;
int y;
int z = 0;
float degreesPerSecond = 0;
float gyroRate = 0;
float currentAngle = 0;
float currentAngleDegrees = 0;
long currMillis = 0;
long pastMillis = 0;
long calibrationSum = 0;
int gyroZero = 0;
int gyroHigh = 0;
int gyroLow = 0;
unsigned long currMicros = 0;
unsigned long pastMicros = 0;
float dt = 0;
void setup(){
  Wire.begin();
  Serial.println("starting up L3G4200D");
  setupL3G4200D(2000); // Configure L3G4200  - 250, 500 or 2000 deg/sec
  delay(1500); //wait for the sensor to be ready
  calibrate();
  attachInterrupt(0, updateAngle, RISING);
  pastMillis = millis();
  getGyroValues();
  pastMicros = currMicros;
  currMicros = micros();
  if(z >= gyroHigh || z <= gyroLow)
    degreesPerSecond = (float)z * 0.00000085; //this value was 0.0000085 but was manually calibrated to its current value
    if (currMicros>pastMicros)  //micros() overflows/resets every ~70 minutes
      dt = (float) (currMicros-pastMicros)/1000000.0;
      dt = (float) ((4294967295-pastMicros)+currMicros)/1000000.0;
    currentAngle += ((p_z + degreesPerSecond)/2) * dt;
    p_z = degreesPerSecond;
    p_z = 0;
  Serial.println(currentAngle * 1000);
  delay(10);
void updateAngle()
  Serial.println("here");
  getGyroValues();
void calibrate()
  for(int i = 0; i < 4000; i++)
    getGyroValues();
    if(z > gyroHigh)
      gyroHigh = z;
    else if(z < gyroLow)
      gyroLow = z;
void getGyroValues(){
  //byte xMSB = readRegister(L3G4200D_Address, 0x29);
  //byte xLSB = readRegister(L3G4200D_Address, 0x28);
  //x = ((xMSB << 8) | xLSB);
  //byte yMSB = readRegister(L3G4200D_Address, 0x2B);
  //byte yLSB = readRegister(L3G4200D_Address, 0x2A);
  //y = ((yMSB << 8) | yLSB);
  byte zMSB = readRegister(L3G4200D_Address, 0x2D);
  byte zLSB = readRegister(L3G4200D_Address, 0x2C);
  z = ((zMSB << 8) | zLSB);
int setupL3G4200D(int scale){
  //From  Jim Lindblom of Sparkfun's code
  // Enable x, y, z and turn off power down:
  writeRegister(L3G4200D_Address, CTRL_REG1, 0b00001111);
  // If you'd like to adjust/use the HPF, you can edit the line below to configure CTRL_REG2:
  writeRegister(L3G4200D_Address, CTRL_REG2, 0b00000000);
  // Configure CTRL_REG3 to generate data ready interrupt on INT2
  // No interrupts used on INT1, if you'd like to configure INT1
  // or INT2 otherwise, consult the datasheet:
  writeRegister(L3G4200D_Address, CTRL_REG3, 0b00001000);
  // CTRL_REG4 controls the full-scale range, among other things:
  if(scale == 250){
    writeRegister(L3G4200D_Address, CTRL_REG4, 0b00000000);
  }else if(scale == 500){
    writeRegister(L3G4200D_Address, CTRL_REG4, 0b00010000);
  }else{
    writeRegister(L3G4200D_Address, CTRL_REG4, 0b00110000);
  // CTRL_REG5 controls high-pass filtering of outputs, use it
  // if you'd like:
  writeRegister(L3G4200D_Address, CTRL_REG5, 0b00000001);
void writeRegister(int deviceAddress, byte address, byte val) {
    Wire.beginTransmission(deviceAddress); // start transmission to device
    Wire.write(address);       // send register address
    Wire.write(val);         // send value to write
    Wire.endTransmission();     // end transmission
int readRegister(int deviceAddress, byte address){
    int v;
    Wire.write(address); // register to read
    Wire.requestFrom(deviceAddress, 1); // read a byte
    while(!Wire.available()) {
        // waiting
    v = Wire.read();
    return v;
Gyros have a zero offset, which needs to be determined and subtracted. That offset will also change with time and temperature.
Thanks, but how to determined and subtracted that offset please :frowning:
Average some readings while the gyro is not moving.
Ok, and after i substruct this value from the gyro ? please could you modify my code please :slight_smile:
Google "arduino calibrate gyro" for lots of code and ideas.
i didn't find good ideas
