L3GD20H Gyro data
Hi below is code i am using to measure angular velovity of my sensor. However the gyro seems to produce a constant value when stationary but when i begin to move the sensor, the values increase by a large amount. for ex, it could stay constant at 20 degrees then when i touch the sensor it may jump to a minus value or even 100+ value. Any help of how I could remove this problem?
Also how could I integrate the velocity to produce the actual angle the gyro moves through?
Thank you.
#include <Wire.h> // Include Arduino I2C library
#include "LiquidCrystal_I2C.h"
LiquidCrystal_I2C lcd(0x27, 16, 2);
#define CTRL1 0x20
#define OUT_X_L 0x28
#define OUT_X_H 0x29
int8_t readData = 0x01;
int8_t writeData = 0x00;
int8_t address = 0xD6; // Device address of L3GD20H with SDO/ADR/SA0 pulled HIGH.
//int8_t address = 0xD4; // Device address of L3GD20H with SDO/ADR/SA0 connected to GND.
int16_t gx; // 16-bit variables to hold raw data from sensor
// initialize the LCD
lcd.begin();
// Turn on the blacklight and print a message.
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("Aerospace Eng");
lcd.setCursor(0,1);
lcd.print("Research Project");
lcd.setCursor(0,2);
lcd.print("2016");
delay(3000);
lcd.clear();
lcd.setCursor(2,0);
lcd.print("Angle");
lcd.setCursor(7,1);
lcd.print("Sensor");
delay(3000);
lcd.clear();
lcd.setCursor(0,1);
lcd.print("By ");
delay(3000);
lcd.clear();
delay(3000);
Wire.begin();
writeReg(CTRL1, 0x0A); // Initialize the sensor by setting control register
delay(100);
gx = (int16_t) readReg(OUT_X_H) <<8 | readReg(OUT_X_L); // typecast as 16-bit
// lcd.begin();
lcd.setCursor(0,0);
lcd.print("Angular Velocity");
//Sensitivity from Page 9 of datasheet - use 8.75 mdps/digit (LSb) for default 245dps.
lcd.setCursor(0,2);
lcd.print(gx0.00875F, DEC); lcd.print("\t");
delay(2000);
int8_t readReg(int8_t reg) {
int8_t buffer = 0;
Wire.beginTransmission((address | writeData) >>1);
Wire.write(reg);
Wire.endTransmission(0);
Wire.requestFrom((address | readData) >>1 , 1);
while(Wire.available() == 0);
buffer = Wire.read();
Wire.endTransmission();
return(buffer);
void writeReg(int8_t reg, int8_t val) {
Wire.write(reg);
Wire.write(val);
Please edit your post to include code tags.
They all do. This is the offset, which must be estimated and subtracted. Unfortunately the offset is very temperature sensitive, so this is not a one-time correction.
