Label applicator with bipolar stepper motor, sensor TCST2103 and UNO
Hi All
I’m still a newbie with arduino, and so far succeeding, but with the following code I have picked up a problem. It all works as supposed to Except that when I switch on the whole operation the push button does not jog to feed the label roll in the m/c, ONLY after I pass something through the sensor does it all work. I know its something to how the code is written. Can I get help please. Any suggestions or bad mouthing bad coding is also fine.
Thanks
John
[code]
//    Label Dispencing Driver -  Using Arduino UNO to Program.
//  Control (L298N Driver) of a 4 wire Bipolar stepper motor with optical-sensor (TCST2103),
//  reading labels on a reel (28mm x 32mm) with a spacing of 3mm  between labels. A led confirms
//  sensor status and (JOG/INCH) delay. A pushbutton is used to (JOG/INCH) the motor with a 2 sec
//  delay between each push of the button, to feed the labels in the machine till, the sensor can
//  take over, thus starting the procedure of the labels being applied to the product.
//  A 5K Potentiometer is added to adjust the speed of the motor.
#include <Stepper.h>
const int buttonPin = 2;          // pushbutton (pin 2 arduino - pin 4 ATmega 328P)
const int led = 13;               // led indicator (pin 13 arduino - pin 19 ATmega 328)
const int sensor = 3;             // sensor (TCST2103)-(pin 3 arduino - pin 5 ATmega 328)
const int stepsPerRevolution = 200;     // 1.8 degree step motor
int state = LOW;                  // default, no motion detected
int val = 0;                      // variable to store the sensor status (value)
// initialize the stepper library on pins 9 through 12.(L298N Driver)
Stepper myStepper(stepsPerRevolution, 9, 10, 11, 12);  //(pin 9-12 arduino - pin 15-18 ATmega 328)
int stepCount = 0;              // number of steps the motor has taken
int buttonState = 0;            // variable for reading the pushbutton status
  pinMode(led, OUTPUT);         // initialize LED as an output
  pinMode(sensor, INPUT);       // initialize sensor as an input
  pinMode(buttonPin, INPUT);    // initialize pushbutton pin as an input:
  val = digitalRead(sensor);           // read sensor value
  if (val == LOW)                      // sensor value low
    buttonState = digitalRead(buttonPin);  // read button value
  if (buttonState == HIGH)    {        // button state high
    //val = digitalRead(sensor);         // read sensor value
    //if (val == LOW)                    // sensor value low
    digitalWrite(led, HIGH);           // turn led on
    myStepper.step(200);               // motor run
    delay (2000);                      // delay 2sec between each push
    if (buttonState == LOW)              // button state low
      digitalWrite(led, LOW);            // turn led off
    myStepper.step(0);                   // stop motor
    if (val == HIGH)   {                 // sensor value high
      int sensorReading = analogRead(A0);   // pot to adjust motor speed (0v-AO-5v)
      // map it to a range from 100 to 255:
      int motorSpeed = map(sensorReading, 0, 1023, 100, 255);
      if (motorSpeed > 100)
        myStepper.setSpeed(motorSpeed);     // set the motor speed:
      // step 1/200 of a revolution:
      myStepper.step(stepsPerRevolution / 200); // step 1/200 of a revolution:
[/code]
I don't see any code to activate pull_up resistors on your button and you look for button state HIGH.
So you must be switching to 5V, do you have a PULL_DOWN resistor fitted to pull the input pin down when the button is OFF?
Tom... :slight_smile:
Hi and thanks,
I’ll put my project board to show. I made it this way so I could test each section one at a time and then connect all up and try it. Like I said- when I power up and push tact switch motor won’t turn, if I pass something through the sensor the motor turns and after this when I press the tact the motor will turn every time I press the tact for the 200 steps as set in code. Does it make sense my explanation ?
Label application driver with Bipolar Stepper.pdf (137 KB)
Thanks for PCB pattern, but can you please post a copy of your circuit, in CAD or a picture of a hand drawn circuit in jpg, png?
The schematic will be easier to read.
Good to see you are doing it in stages.
Thanks.. Tom.. :slight_smile:
Hi There
Thanks again I'll post a simple basic circuit of the Part I think you want to see, its RIMU hope you can see it - load it. Nearly broke my arm doin it. :slight_smile:
John
Hi Here’s circuit
john
Label Applicator Circuit.pdf (144 KB)
You should be able to export an image in jpg.
Have you put bypass caps around the regulator that they recommend in the data sheet?
Hi Tom
If U can please tell me how to export to jpg I'll be grateful I'm using win 7 ultimate
john
Hi
Yes there's two 104 ceramic caps over the regulator and one 104 over the 328 power pins plus the power supply is well regulated.
john
