Ladyada Motor Shield
I recently got a LadyAda Motor shield for arduino. I am a noob at the programming language, and I just copied the sample code to test out the shield. When I go to upload the code, it says: 'AF_DCMotor' does not name a type. Does anyone know how to fix the code?
(deleted)
Here is the Sample Code:
#include <AFMotor.h>
AF_DCMotor motor(2, MOTOR12_64KHZ); // create motor #2, 64KHz pwm
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println(“Motor test!”);
motor.setSpeed(200); // set the speed to 200/255
Serial.print(“tick”);
motor.run(FORWARD); // turn it on going forward
Serial.print(“tock”);
motor.run(BACKWARD); // the other way
Serial.print(“tack”);
motor.run(RELEASE); // stopped
Make sure you download the AFMotor.H and put it in the appropriate place on your computer.
I'm a newbie also, did the same thing.
Edit: http://www.ladyada.net/make/mshield/download.html
