Laggy GPS with dht22 sensor
hi there. I have a perfectly fine GPS speedometer, when I add the dht22 sensor GPS becomes laggy and the speed freezes sometimes. I couldn't understand the problem because both the GPS and the sensor work perfectly on their own but when I combine them this happens.
Here is my code:
[code]
#include "DHT.h"
#include <Arduino.h>
 Connections:
 GPS TX -> Arduino 0 (disconnect to upload this sketch)
 GPS RX -> Arduino 1
 Screen SDA -> Arduino A4
 Screen SCL -> Arduino A5
#include "U8glib.h"
U8GLIB_SH1106_128X64 u8g(U8G_I2C_OPT_DEV_0|U8G_I2C_OPT_FAST);
#define GPS Serial
#define DHTPIN 10
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
unsigned long lastDHT;
int dhtReadInterval = 10000;
float hum;  //Stores humidity value
float temp;
const unsigned char UBLOX_INIT[] PROGMEM = {
  // Disable NMEA
  0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x24, // GxGGA off
  0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x01,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x2B, // GxGLL off
  0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x02,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x32, // GxGSA off
  0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x03,0x00,0x00,0x00,0x00,0x00,0x01,0x03,0x39, // GxGSV off
  0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x04,0x00,0x00,0x00,0x00,0x00,0x01,0x04,0x40, // GxRMC off
  0xB5,0x62,0x06,0x01,0x08,0x00,0xF0,0x05,0x00,0x00,0x00,0x00,0x00,0x01,0x05,0x47, // GxVTG off
  // Disable UBX
  0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x17,0xDC, //NAV-PVT off
  0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x02,0x00,0x00,0x00,0x00,0x00,0x00,0x12,0xB9, //NAV-POSLLH off
  0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x03,0x00,0x00,0x00,0x00,0x00,0x00,0x13,0xC0, //NAV-STATUS off
  // Enable UBX
  0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x07,0x00,0x01,0x00,0x00,0x00,0x00,0x18,0xE1, //NAV-PVT on
  //0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x02,0x00,0x01,0x00,0x00,0x00,0x00,0x13,0xBE, //NAV-POSLLH on
  //0xB5,0x62,0x06,0x01,0x08,0x00,0x01,0x03,0x00,0x01,0x00,0x00,0x00,0x00,0x14,0xC5, //NAV-STATUS on
  // Rate
 0xB5,0x62,0x06,0x08,0x06,0x00,0x64,0x00,0x01,0x00,0x01,0x00,0x7A,0x12, //(10Hz)
  //0xB5,0x62,0x06,0x08,0x06,0x00,0xC8,0x00,0x01,0x00,0x01,0x00,0xDE,0x6A, //(5Hz)
  //0xB5,0x62,0x06,0x08,0x06,0x00,0xE8,0x03,0x01,0x00,0x01,0x00,0x01,0x39 //(1Hz)
const unsigned char UBX_HEADER[] = { 0xB5, 0x62 };
struct NAV_PVT {
  unsigned char cls;
  unsigned char id;
  unsigned short len;
  unsigned long iTOW;          // GPS time of week of the navigation epoch (ms)
  unsigned short year;         // Year (UTC)
  unsigned char month;         // Month, range 1..12 (UTC)
  unsigned char day;           // Day of month, range 1..31 (UTC)
  unsigned char hour;          // Hour of day, range 0..23 (UTC)
  unsigned char minute;        // Minute of hour, range 0..59 (UTC)
  unsigned char second;        // Seconds of minute, range 0..60 (UTC)
  char valid;                  // Validity Flags (see graphic below)
  unsigned long tAcc;          // Time accuracy estimate (UTC) (ns)
  long nano;                   // Fraction of second, range -1e9 .. 1e9 (UTC) (ns)
  unsigned char fixType;       // GNSSfix Type, range 0..5
  char flags;                  // Fix Status Flags
  unsigned char reserved1;     // reserved
  unsigned char numSV;         // Number of satellites used in Nav Solution
  long lon;                    // Longitude (deg)
  long lat;                    // Latitude (deg)
  long height;                 // Height above Ellipsoid (mm)
  long hMSL;                   // Height above mean sea level (mm)
  unsigned long hAcc;          // Horizontal Accuracy Estimate (mm)
  unsigned long vAcc;          // Vertical Accuracy Estimate (mm)
  long velN;                   // NED north velocity (mm/s)
  long velE;                   // NED east velocity (mm/s)
  long velD;                   // NED down velocity (mm/s)
  long gSpeed;                 // Ground Speed (2-D) (mm/s)
  long heading;                // Heading of motion 2-D (deg)
  unsigned long sAcc;          // Speed Accuracy Estimate
  unsigned long headingAcc;    // Heading Accuracy Estimate
  unsigned short pDOP;         // Position dilution of precision
  short reserved2;             // Reserved
  unsigned long reserved3;     // Reserved
NAV_PVT pvt;
void calcChecksum(unsigned char* CK) {
  memset(CK, 0, 2);
  for (int i = 0; i < (int)sizeof(NAV_PVT); i++) {
    CK[0] += ((unsigned char*)(&pvt))[i];
    CK[1] += CK[0];
long numGPSMessagesReceived = 0;
bool processGPS() {
  static int fpos = 0;
  static unsigned char checksum[2];
  const int payloadSize = sizeof(NAV_PVT);
  while ( GPS.available() ) {
    byte c = GPS.read();
    if ( fpos < 2 ) {
      if ( c == UBX_HEADER[fpos] )
        fpos++;
        fpos = 0;
    else {
      if ( (fpos-2) < payloadSize )
        ((unsigned char*)(&pvt))[fpos-2] = c;
      fpos++;
      if ( fpos == (payloadSize+2) ) {
        calcChecksum(checksum);
      else if ( fpos == (payloadSize+3) ) {
        if ( c != checksum[0] )
          fpos = 0;
      else if ( fpos == (payloadSize+4) ) {
        fpos = 0;
        if ( c == checksum[1] ) {
          return true;
      else if ( fpos > (payloadSize+4) ) {
        fpos = 0;
  return false;
  GPS.begin(9600);
  dht.begin();
  u8g.setColorIndex(1);
  // send configuration data in UBX protocol
  for(unsigned int i = 0; i < sizeof(UBLOX_INIT); i++) {
    GPS.write( pgm_read_byte(UBLOX_INIT+i) );
    delay(5); // simulating a 38400baud pace (or less), otherwise commands are not accepted by the device.
long gSpeed = 0;
int numSV = 0;
unsigned long lastScreenUpdate = 0;
char speedBuf[16];
char satsBuf[16];
char unit[6];
char* spinner = "/-\\|";
byte screenRefreshSpinnerPos = 0;
byte gpsUpdateSpinnerPos = 0;
  if ( processGPS() ) {
    numSV = pvt.numSV;
    gSpeed = pvt.gSpeed;
    gpsUpdateSpinnerPos = (gpsUpdateSpinnerPos + 1) % 4;
  unsigned long now = millis();
  if ( now - lastScreenUpdate > 100 ) {
    updateScreen();
    lastScreenUpdate = now;
    screenRefreshSpinnerPos = (screenRefreshSpinnerPos + 1) % 4;
  if (millis() - lastDHT >= (unsigned long) dhtReadInterval) //check if time has elapsed
    lastDHT = millis();  //save for next time
  hum = dht.readHumidity();
  temp= dht.readTemperature();
void draw() {
   //  // graphic commands to redraw the complete screen should be placed here
  //u8g.setScale2x2(); don't do this!
//  u8g.setFont(u8g_font_courB24);
u8g.setFont(u8g_font_ncenB24n);
//u8g.setFont(u8g_font_gdb30n);
  u8g.drawStr( 6, 60, speedBuf);
  u8g.setFont(u8g_font_helvR10r);
  u8g.drawStr( 99, 60, unit);
  //u8g.undoScale();
 // u8g.setFont(u8g_font_fur11r);
  u8g.drawStr( 2, 12, satsBuf);
  u8g.setPrintPos(58, 12);
  u8g.print("T: "),u8g.print(temp);
  u8g.setFont(u8g_font_helvR08);
  u8g.setPrintPos(115, 12);
  u8g.write(0xB0), u8g.print("C");
  u8g.setPrintPos(58, 25);
  u8g.print("H: "),u8g.print(hum) ;
  u8g.setPrintPos(116, 25);
  u8g.print("%");
void updateScreen() {
  int kmh = gSpeed * 0.0036;
  sprintf(speedBuf, "%d", kmh);
  sprintf(unit, "%4s", "km/h");
  sprintf(satsBuf, "%c %c %d %s", spinner[screenRefreshSpinnerPos], spinner[gpsUpdateSpinnerPos], numSV, " ");
  u8g.firstPage();
  do {
    draw();
  } while( u8g.nextPage() );
[/code]
and this is my harware:
arduino nano
neo 7m GPS module
sh1106 OLED
DHT22 temp and humidity sensor
I would appreciate any help.
Thanks in advance.
I'd guess that it's the display that's causing the issue, try commenting out that piece.
You can also switch to a non-blocking library for your sensor: https://github.com/olewolf/DHT_nonblocking
As for the screen, you are completely redrawing it every 100msec. I seriously doubt your temperature or humidity is changing that quickly. Slow that down to something like every minute.
which part do you think is causing the issue?
I'll test the library. as for the screen I use that redrawing for the gps speedo not the sensor.
I'd suggest stopping the drawing altogether as a test. If you're convinced it's the dht, maybe write a test sketch and measure how long it actually takes to get the two readings.
