Sure! Nobody will hold you back doing it.
ha, yeah, i walked into that one. i meant; will it work without internet access to the arduino?
Gateway is necessary only if your device should have Internet access.
so i can omit the gateway?
Subnet is necessary but you probably can live with the default 255.255.255.0 because it's used by all home devices. Server port is necessary too as the client will connect to that port and the server should know about. For a web server it's usually 80.
it's a lan server, and won't be connected to the internet at all. also, i successfully ran the example sketch below, and i notice that it contains no subnet or gateway, but almost every other example, especially those with html gui's, do contain them. i have no issue adding them, but i'm not sure what's required.
Web Server Demo
thrown together by Randy Sarafan
Allows you to turn on and off an LED by entering different urls.
To turn it on:
http://your-IP-address/$1
To turn it off:
http://your-IP-address/$2
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
* Connect an LED to pin D2 and put it in series with a 220 ohm resistor to ground
Based almost entirely upon Web Server by Tom Igoe and David Mellis
Edit history:
created 18 Dec 2009
by David A. Mellis
modified 4 Sep 2010
by Tom Igoe
#include <SPI.h>
#include <Ethernet.h>
boolean incoming = 0;
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = { 0x00, 0xAA, 0xBB, 0xCC, 0xDA, 0x02 };
IPAddress ip(191,11,1,1); //<<< ENTER YOUR IP ADDRESS HERE!!!
// Initialize the Ethernet server library
// with the IP address and port you want to use
// (port 80 is default for HTTP):
EthernetServer server(80);
pinMode(2, OUTPUT);
// start the Ethernet connection and the server:
Ethernet.begin(mac, ip);
server.begin();
// listen for incoming clients
if (client) {
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
//reads URL string from $ to first blank space
if(incoming && c == ' '){
incoming = 0;
if(c == '
incoming = 1;
//Checks for the URL string $1 or $2
if(incoming == 1){
Serial.println(c);
if(c == '1'){
Serial.println("ON");
digitalWrite(2, HIGH);
if(c == '2'){
Serial.println("OFF");
digitalWrite(2, LOW);
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
