Bonjour communauté d’arduino ^^ , aujourd’hui je me suis lancer dans un projet de trieurs de jeton
plus particulièrement sur un composant , le TCS 34725 et je chercher un programme pour le mettre en oeuvre , mes recherches m’ont menée vers le programme si dessous , seul problème , je travail en Micro C et non en langage C , je cherche donc des informations pour traduire ce langage
Hello arduino community ^^, today I am embarking on a project of token sorters
more particularly on a component, the TCS 34725 and I am looking for a program to implement, my research directed to the program if below, the only problem, I work in the micro C and not in the language C, so I look for information to translate this language
–This is an example that uses the TCS34725 Color Sensor on the I2C Bus on EIO4(SCL) and EIO5(SDA), LED pin to FIO6
–See datasheet for TCS34725 for more information
–Outputs data to Registers:
–Raw:
–clear: 46100
–red: 46102
–green: 46104
–blue: 46106
–Intensity:
–red: 46000
–green: 46002
–blue: 46004
MB.W(2006, 0, 0)-- turn LED on, connected to FIO6
fwver = MB.R(60004, 3)
devType = MB.R(60000, 3)
if (fwver < 1.0224 and devType == 7) or (fwver < 0.2037 and devType == 4) then
print(“This lua script requires a higher firmware version (T7 Requires 1.0224 or higher, T4 requires 0.2037 or higher). Program Stopping”)
MB.W(6000, 1, 0)
end
SLAVE_ADDRESS = 0x29
I2C.config(13, 12, 65516, 0, SLAVE_ADDRESS, 0)–configure the I2C Bus
addrs = I2C.search(0, 127)
addrsLen = table.getn(addrs)
found = 0
for i=1, addrsLen do–verify that the target device was found
if addrs == SLAVE_ADDRESS then
- print(“I2C Slave Detected”)*
- found = 1*
- break*
- end*
end
if found == 0 then - print(“No I2C Slave detected, program stopping”)*
- MB.W(6000, 1, 0)*
end
–init slave
MB.W(2006, 0, 1)-- turn LED on, connected to FIO6
*LJ.IntervalConfig(0, 1500) *
stage = 0 --used to control program progress
while true do - if LJ.CheckInterval(0) then*
- if stage == 0 then*
- LJ.IntervalConfig(0, 100)*
- stage = 1*
- elseif stage == 1 then*
- I2C.write({0x80+0x00, 0x03})*
- LJ.IntervalConfig(0, 50)*
- stage = 2*
- elseif stage == 2 then*
- dataIn = {}*
- for i=0,3 do*
_ I2C.write({0x80+0x14+2i, 0x80+0x15+2i})_ - raw = I2C.read(2)*
_ table.insert(dataIn, raw[2]*256+raw[1])_ - end*
- MB.W(46100, 1, dataIn[1])–write clear light value in raw form*
- MB.W(46102, 1, dataIn[2])–write red*
- MB.W(46104, 1, dataIn[3])–write green*
- MB.W(46106, 1, dataIn[4])–write blue*
- red = ((dataIn[2])/dataIn[1])*
- MB.W(46000, 3, red)*
- green = ((dataIn[3])/dataIn[1])*
- MB.W(46002, 3, green)*
- blue = ((dataIn[4])/dataIn[1])*
- MB.W(46004, 3, blue)*
- –print(red, green, blue)–print relative (to clear) intesity*
- print(“Clear:”, dataIn[1], “Red:”, dataIn[2], “Green:”, dataIn[3], “Blue:”, dataIn[4])–print absolute intesity*
- if red > blue and red > green then*
- print(“Dominant: Red”)*
- elseif blue > green and blue > red then*
- print(“Dominant: Blue”)*
- else*
- print(“Dominant: Green”)*
- end*
- print("-----------")*
- LJ.IntervalConfig(0, 1000)*
- stage = 0*
- end*
- end*
end
