Hi guys, seems like I have almost finished my lap timer build. (first ever project)
I have it all working well, I just need a quick pointer,
I have the timer displaying in just milliseconds, so if i did 1 lap in 1.350 seconds, it would simply display as 1350. Is there a quick and easy way to change this to read with a decimal point, so it would say 1.350.
Here is the code I am currently using. Any help would be much appreciated.
#include <LiquidCrystal.h>
VERSION 0.3
-Added Green LED For Best Round
// PIN CONFIGURATION
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int laserPin = 13;
int buttonPin1 = 7;
int buttonPin2 = 8;
int speakerPin = 9;
int ledPin1 = 0; // red
int ledPin2 = 1; // red
int ledPin3 = 10; // green
States // The central state the timer is in
0 = pause;
1 = countdown;
2 = running;
int state = 0;
boolean displayLastRound = true;
boolean running = false;
int lightLevel = 0;
long lastHit = 0; //time of the last hit in the barrier (absolut)
boolean lock; // locks the light barrier while a car is passing. The look is removed as soon the car left the lightbeam and the roundTreshold time has passed
long lastRound = 0; // time of the lastround (absolut)
long bestRound = 0; // time of the bestround (relative)
int roundNr = 0;
int laserTreshold = 10;
int roundTreshold = 300; // minimum time that has to pass before a new round is counted
// Absolut time for pressing buttons
long lastPress1 = 0;
long lastPress2 = 0;
// LED Timer
long timeLEDGreen = 0;
pinMode(laserPin, OUTPUT);
pinMode(buttonPin1, INPUT);
pinMode(buttonPin2, INPUT);
pinMode(speakerPin, OUTPUT);
pinMode(ledPin1, OUTPUT);
pinMode(ledPin2, OUTPUT);
pinMode(ledPin3, OUTPUT);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print("Arduino");
lcd.setCursor(0, 1);
lcd.print("Laser Lap Timer ");
delay(1500);
lcd.print("Nath's Lap ");
lcd.print("Timer ");
//Serial.begin(9600);
delay(1500);
if(!digitalRead(buttonPin1)){
button1Pressed();
if(!digitalRead(buttonPin2)){
button2Pressed();
switch (state){
case 0:
statePaused();
case 1:
stateCountdown();
case 2:
stateRunning();
void didFinishRound(){
if(roundNr > 0)lastRound = millis()-lastHit;
if (bestRound == 0){
bestRound = lastRound;
if (lastRound < bestRound){
timeLEDGreen = millis()+1000;
lastHit = millis();
lock = true;
++roundNr;
void statePaused(){
digitalWrite(ledPin1, LOW);
digitalWrite(ledPin2, LOW);
digitalWrite(ledPin3, LOW);
digitalWrite(laserPin,LOW);
lcd.print("Press right ");
lcd.print("button to start");
void stateRunning(){
//switch laser on
digitalWrite(laserPin,HIGH);
//mesasure light
lightLevel = analogRead(0);
lightLevel = map(lightLevel, 0, 900, 0, 255);
lightLevel = constrain(lightLevel, 0, 255);
//Serial.println(lightLevel);
// react to light
if(lightLevel < laserTreshold){
//digitalWrite(ledPin,LOW);
lock = false;
else{
// digitalWrite(ledPin,HIGH);
if (millis()-lastHit > roundTreshold && lock == false){
didFinishRound();
// We have'nt finished the first round
if(roundNr == 0){
lcd.setCursor(0,0);
lcd.print("Standby... ");
lcd.setCursor(0,1);
lcd.print(" ");
// Display the time and best / last round
else{
displaySecondLine();
displayFirstLine();
// turn off all LED
if (timeLEDGreen > millis()){
digitalWrite(ledPin3, HIGH);
else{
void stateCountdown(){
lcd.clear();
lcd.print("Ready ");
digitalWrite(ledPin1, HIGH);
playNote('c',300);
lcd.print("Set ");
digitalWrite(ledPin2, HIGH);
playNote('c',300);
lcd.print("Go ");
playNote('g',600);
state = 2;
void displayFirstLine(){
lcd.print("Rd");
lcd.print(" ");
lcd.print(roundNr);
lcd.print(" ");
lcd.print(millis()-lastHit);
lcd.print("ms");
lcd.print(" ");
void displaySecondLine(){
if(displayLastRound){
lcd.print("Last ");
lcd.print(lastRound);
lcd.print("ms");
lcd.print(" ");
else{
lcd.print("Best ");
lcd.print(bestRound);
lcd.print("ms");
lcd.print(" ");
void button1Pressed(){
if(millis()-lastPress1 > 800){
lastPress1 = millis();
displayLastRound = !displayLastRound;
void button2Pressed(){
if(millis()-lastPress2 > 800){
lastPress2 = millis();
if (state == 0){
state = 1;
if (state == 2){
roundNr = 0;
bestRound = 0;
lastRound = 0;
state = 0;
void playTone(int tone, int duration) {
for (long i = 0; i < duration * 1000L; i += tone * 2) {
digitalWrite(speakerPin, HIGH);
delayMicroseconds(tone);
digitalWrite(speakerPin, LOW);
void playNote(char note, int duration) {
char names[] = {
'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C' };
int tones[] = {
1915, 1700, 1519, 1432, 1275, 1136, 1014, 956 };
// play the tone corresponding to the note name
for (int i = 0; i < 8; i++) {
if (names[i] == note) {
playTone(tones[i], duration);
