Large font, problems clearing display
Good day folks. I need a hand just finishing up my code for a 16x2 display that is displaying large fonts. I have it displaying 0-360 for a analog pot input. It works mostly except for clearing off the display for the "1" I notice. It still displays pieces of the old numbers. It is working except for that.
I would like a suggestion or a code edit to make it display cleanly.
Have a look and see what you think.
Thanks!!
const int analogInPin = A0;  // Analog input pin that the potentiometer is attached to
int sensorValue = 0;        // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
//char outputValueChar[5];
int hundreds;
int tens;
int ones;
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// the 8 arrays that form each segment of the custom numbers
byte LT[8] =
  B00111,
  B01111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte UB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B00000
byte RT[8] =
  B11100,
  B11110,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111
byte LL[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B01111,
  B00111
byte LB[8] =
  B00000,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
byte LR[8] =
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11111,
  B11110,
  B11100
byte UMB[8] =
  B11111,
  B11111,
  B11111,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111
byte LMB[8] =
  B11111,
  B00000,
  B00000,
  B00000,
  B00000,
  B11111,
  B11111,
  B11111
// loop counter
int x = 0;
  // assignes each segment a write number
  lcd.createChar(0,LT);
  lcd.createChar(1,UB);
  lcd.createChar(2,RT);
  lcd.createChar(3,LL);
  lcd.createChar(4,LB);
  lcd.createChar(5,LR);
  lcd.createChar(6,UMB);
  lcd.createChar(7,LMB);
  // sets the LCD's rows and colums:
  lcd.begin(16, 2);
void custom0()
{ // uses segments to build the number 0
  lcd.setCursor(x, 0); // set cursor to column 0, line 0 (first row)
  lcd.write((byte)0);  // call each segment to create
  lcd.write(1);  // top half of the number
  lcd.write(2);
  lcd.setCursor(x, 1); // set cursor to colum 0, line 1 (second row)
  lcd.write(3);  // call each segment to create
  lcd.write(4);  // bottom half of the number
  lcd.write(5);
void custom1()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(2);
  lcd.setCursor(x+1,1);
  lcd.write(5);
void custom2()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(7);
void custom3()
  lcd.setCursor(x,0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(2);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom4()
  lcd.setCursor(x,0);
  lcd.write(3);
  lcd.write(4);
  lcd.write(2);
  lcd.setCursor(x+2, 1);
  lcd.write(5);
void custom5()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(7);
  lcd.write(7);
  lcd.write(5);
void custom6()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(6);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom7()
  lcd.setCursor(x,0);
  lcd.write(1);
  lcd.write(1);
  lcd.write(2);
  lcd.setCursor(x+1, 1);
  lcd.write((byte)0);
void custom8()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(3);
  lcd.write(7);
  lcd.write(5);
void custom9()
  lcd.setCursor(x,0);
  lcd.write((byte)0);
  lcd.write(6);
  lcd.write(2);
  lcd.write(5);
  // read the analog in value:
  sensorValue = analogRead(analogInPin);
  // map it to the range of the analog out:
  outputValue = map(sensorValue, 0, 1023, 0, 360);
  // print the results to the serial monitor:
  Serial.print("sensor = " );
  Serial.print(sensorValue);
  Serial.print("\t output = ");
  Serial.println(outputValue);
  String stringOne =  String(outputValue);
  // prints the value of outputValue
  //Serial.print("Output value string is ");
  //Serial.println(stringOne);
  x=0;
  hundreds = outputValue /100;
  //Serial.print(hundreds);
  switch (hundreds) {
    case 3:
      lcd.print("    ");
      custom3();
  case 2:
    lcd.print("    ");
    custom2();
  case 1:
   lcd.print("    ");
   custom1();
  case 0:
  lcd.print("   ");
  custom0();
  tens=outputValue /10;
  tens=tens%10;
  //Serial.println(tens);
  switch (tens) {
    case 9:
      x=x+3;
      lcd.print("   ");
      custom9();
     case 8:
     x=x+3;
     lcd.print("   ");
     custom8();
     case 7:
     x=x+2;
     lcd.print("   ");
     custom7();
     case 6:
     x=x+3;
     lcd.print("   ");
     custom6();
     case 5:
     x=x+3;
     lcd.print("   ");
     custom5();
     case 4:
     x=x+3;
     lcd.print("   ");
     custom4();
     case 3:
     x=x+3;
     lcd.print("   ");
     custom3();
     case 2:
     x=x+3;
     lcd.print("   ");
     custom2();
     case 1:
     x=x+3;
     lcd.print("   ");
     custom1();
     if (outputValue<10)
     //case 0:
     x=x+3;
     lcd.print("   ");
     custom0();
    case 0:
    x=x+3;
    lcd.print("   ");
    custom0();
  ones=outputValue%10;
  //ones=ones%100;
 // Serial.println(ones);
    switch (ones) {
    case 9:
      x=x+3;
      lcd.print("   ");
      custom9();
     case 8:
     x=x+3;
     lcd.print("   ");
     custom8();
     case 7:
     x=x+3;
     lcd.print("   ");
     custom7();
     case 6:
     x=x+3;
     lcd.print("   ");
     custom6();
     case 5:
     x=x+3;
     lcd.print("   ");
     custom5();
     case 4:
     x=x+3;
     lcd.print("   ");
     custom4();
     case 3:
     x=x+3;
     lcd.print("   ");
     custom3();
     case 2:
     x=x+3;
     lcd.print("   ");
     custom2();
     case 1:
     x=x+3;
     lcd.print("   ");
     custom1();
     case 0:
     x=x+3;
     lcd.print("   ");
     custom0();
  lcd.setCursor(0,1);
  lcd.print(outputValue); */
  //delay(300);
  //lcd.clear();
  if (outputValue < 100)
      x=0;
      lcd.print("   ");
  // wait 2 milliseconds before the next loop
  // for the analog-to-digital converter to settle
  // after the last reading:
  //delay(10);
When you're printing, you erase by sending " "(4 spaces).
This way you are clearing one line.
I'm guessing your characters are 2 lines high.
In that case you would also need to clear the second line, and i don't see that happening.
So the bottom part of your characters aren't erased.
Also, i wouldn't erase and then call your printing routine.
I would put the erasing part inside the printing routine.
All characters are equally wide, so you know where to put an empty space just as well as where to put a filled space.
Just edit the printing of your characters to also include the empty space, by sending a space instead of not sending anything and leaving whatever is there to stay.
Thanks MAS3, I tried that and it didn't work at all. The characters didn't print at all. Hmmm I put it in where it prints the characters like this,
void custom1()
  lcd.setCursor(x,0);
  lcd.write("   ");
  lcd.write(1);
  lcd.write(2);
  lcd.write("   ");
  lcd.write(5);
and it stopped printing them. I thought it would just clear them as well.
If use the lcd.clear it erases it too fast to make the characters legible, or it's too slow and it blinks.
Anyone have any ideas please?
Ehm.
After clearing, you need to go back to where you wanted to print.
So try this:
void custom1()
  lcd.setCursor(x,0);
  lcd.write("   ");       //Erasing
  lcd.setCursor(x,0);     //Reset cursor
  lcd.write(1);
  lcd.write(2);
  lcd.setCursor(x+1,1);    //Reset cursor
  lcd.write(5);
Thanks MAS3 I'll give it a go.
